Go Back   HomeSeer Message Board > Irrigation Plug-ins > Irrigation Discussion > EZFlora Insteon Irrigation Controller Plug-in
EZFlora Insteon Irrigation Controller Plug-in Discussions of Adam Telford's EZFlora Insteon Irrigation Controller Plug-in
Old October 5th, 2013, 12:03 PM
hurry4it hurry4it is offline
HS3 Beta EZFlora Plugin v2.0.0.1
The EZFlora Plugin has been upgraded to version 2.0.0.1 which is compatible with HS3. The plugin is available for download in the HS3 updater and inlcudes all features of version 1.1.2.0.
New Features:
- Add/Remove individual HS devices
- Enhanced Insteon communication failure reporting and handling
Requirements:
- Requires mnSandler Insteon Plugin version 3.0.1.3 or greater
- Insteon plugin must be enabled prior to enabling EZFlora
Notes:
- Manual timer values must be greater than zero for manual device control to function
- Device must be polled to detect rain sensor status changes
- Last active valve must be manually turned off after running diagnostic mode
Coming Soon:
- Detailed instructions for use and operation of the EZFlora
Please let me know if you experience any issues with the plugin and post a copy of the HS log with debug logging enabled.
Adam
EZFlora Plugin Version 1.1.2.0 hurry4it EZFlora Insteon Irrigation Controller Plug-in 0 November 10th, 2012 11:18 PM
EZFlora Plugin Version 1.1.1.0 hurry4it EZFlora Insteon Irrigation Controller Plug-in 3 May 16th, 2012 10:29 AM
EZFlora Plugin Version 1.1.0.0 hurry4it EZFlora Insteon Irrigation Controller Plug-in 0 February 25th, 2012 08:55 PM
EZFlora Plugin Version 1.0.1.0 hurry4it EZFlora Insteon Irrigation Controller Plug-in 0 January 30th, 2012 01:42 AM
EZFlora Plugin Revision History hurry4it EZFlora Insteon Irrigation Controller Plug-in 0 January 30th, 2012 01:24 AM
