Go Back   HomeSeer Message Board > Irrigation Plug-ins > Irrigation Discussion > EZFlora Insteon Irrigation Controller Plug-in
EZFlora Insteon Irrigation Controller Plug-in Discussions of Adam Telford's EZFlora Insteon Irrigation Controller Plug-in
Old April 27th, 2014, 12:48 PM
vbphil vbphil is offline
EZFlora with ISY 994i
I'm starting up HS3 while also continuing my home control with HS2 that I've been using for years and years. I'm using the ISY as my Insteon controller but do all of my lighting from HS with events or just manual control. Also just started using HSTouch on my iPhone, guess I'm slow to catch on with all of this, at least I've dropped X10 for good . I've written programs in the ISY to control EZFlora and all that works fine.
I've thought about using HS3 scripting for my irrigation control instead of the ISY and this is when I notice there's a EZFlora plugin. I'm confused as to why I'd need the plugin. When the EZFlora installed into the ISY I got 8 devices representing the 8 zones to which I can programmatically control anyway I'd like.
If the EZFlora plugin has some valuable functionality will it work with the ISY as the insteon controller?
thanks for any insight you can provide.
-phil
Old April 28th, 2014, 10:43 AM
hurry4it hurry4it is offline
Phil,
The EZFlora plugin is meant to enable the EZFlora to be used with the Mark Sandler Insteon Plugin. The Insteon plugin does not natively support the EZFlora but with the EZFlora plugin, the EZFlora device can be added to Homeseer when using the Insteon plugin and provides the ability to control nearly all of the EZFlora functions.
This plugin is not compatible with the ISY so you would not benefit from it. Your best bet is to continue using the scripting and ISY to control the EZFlora unless you switched over to the Insteon plugin in.
Adam
Old April 28th, 2014, 01:30 PM
Adam,
Thanks for the advice.
Years ago I was using the SimpleHomeNet Utility Suite v2.01 program with the EZFlora to set up the EZFLORA watering programs and other links and settings. Does the HS EZFlora plugin do everything that you could do with SimpleHomeNet Utility Suite v2.01?
-phil
Old April 30th, 2014, 12:07 PM
Phil,
It has been a while since I used the SimpleHomeNet Utility, but the EZFlora plugin provides most of the functionality supported by the utility. The only features that are not supported by the plugin are performing a factory reset and setting up/modifying Insteon links (I may have missed one or two, but the plugin was developed to use as much of the EZFlora functionality as possible through the Insteon interface).
Adam
What's the best approach for moving from an ISY 99i to an ISY 994i? tmcgowan ISY Plug-in Beta (3P) 2 December 15th, 2013 12:06 PM
EZFlora and HS3 ? nfrobertson EZFlora Insteon Irrigation Controller Plug-in 2 August 7th, 2013 10:38 AM
ISY 994i firmware version 4.0.2 Barry Gordon ISY Plug-in Beta (3P) 1 March 4th, 2013 04:01 PM
Rain8Net or EZFlora or other? DigitalAnvil Irrigation Discussion 10 February 24th, 2013 01:55 PM
My EZFlora keeps inhibiting... codemonkey EZFlora Insteon Irrigation Controller Plug-in 24 November 11th, 2012 05:03 AM
