Go Back   HomeSeer Message Board > Irrigation Plug-ins > Irrigation Discussion > EZFlora Insteon Irrigation Controller Plug-in
EZFlora Insteon Irrigation Controller Plug-in Discussions of Adam Telford's EZFlora Insteon Irrigation Controller Plug-in
Old October 4th, 2014, 11:32 AM
field888 field888 is offline
Strange problem when using remote I/O link
HI,
I have migrated to HS3, including EZFlora and everything works fine (almost).
I can run my programs via event actions.
I can manually start/stop any valve directly from the device control screen.
I can run any valve or combination of valves directly from a timed event (in case I need a temporary schedule not covered by the programs).
The issue is with directly controlling a valve through an event which is initiated by the remote I/O link. A button on the I/O link sets the valve to ON. Pressing the same button again sets the valve to OFF. The log shows device control setting the valve on, but no response from the valve. What is really strange is that 2 of the 4 valves work fine using the i/O link. Strange and confusing.!!
any thoughts?
HS3 3.0.0.96
EZFlora 2.0.0.1
Insteon 3.0.4.4
Old October 5th, 2014, 09:07 AM
hurry4it hurry4it is offline
I'm not sure what could be causing it, but I'll look into it. Please post a copy of the EZflora log with debug logging enabled so I can get a better understanding of what is happening in the plugin.
Adam
Old October 5th, 2014, 11:20 AM
OK Adam,
I'm not sure how to parse & store logs in HS3 yet, so I did a screen capture to get this to you quicker. If you can't read it, maybe I could email it to you.
the sequence for this test was:
turn valve1 on, then off from screen
turn valve1 on, then off from the remote i/o device
turn valve1 on, then off from screen again.
In all three scenarios, the valve1 status on the device screen showed on/off as expected, but in scenario 2, the actual valve did not come on.
Old October 5th, 2014, 11:22 AM
Zipped the debug file,
Doug
Old October 5th, 2014, 11:43 PM
It looks like there may be a problem with the plugin on how it handles the event calls from HS. Could you also post a capture of the log doing the same sequence with one of the valves that works being triggered by the IOlinc?
Adam
Old October 6th, 2014, 10:53 AM
Adam,
I reset the I/O link and it appears to be working now with all 4 valves. I'll continue to test it for awhile, but I don't think there is any issue with your plug-in. Thanks for your continued support.
Doug
Old October 6th, 2014, 11:22 AM
That is great news! I'm glad it is working now. Let me know if you run into any problems with it.
Adam
How to link remote, KPL, and FanLinc? BrunDog Insteon Plug-in (Mark Sandler) 13 January 17th, 2013 08:20 AM
Schlage Link Lock remote Acces from HSTouch marlinman4 HSTouch™ 2 June 20th, 2011 06:12 PM
strange problem happnatious1 HS2 / HSPRO 7 January 24th, 2010 11:46 PM
Remote link database could *not* be updated, programming failed. loowee Lighting & Primary Technology Discussion 2 January 25th, 2009 07:11 PM
Reading remote link database errors (Bug?) edgar1898 Insteon Plug-in (Mark Sandler) 1 December 24th, 2006 03:52 PM
