This looks dooable: https://github.com/nfarina/homebridge. It appears one can run this server on a pi and send http commands from there to control server. I'll probably try it when I get home. I know the vera people are using it. Anyone else?
Homekit and Homeseer
jayman,
could you detail how and what you did to control with Siri. Like a how to would be great.
Cause I looked at the link and didn't quite get it.Tom
I literally just followed the directions on the link. I put it on a rasberry pi and I use a program called winscp to alter the config file because I don't know much about linux. I got the idea from a vera thread here: http://forum.micasaverde.com/index.php?topic=31716.0. Apparently someone in that thread has a how-to with windows using node.js here: http://forum.micasaverde.com/index.p...=31716.65;wap2
Very cool tip. Got it working on Ubuntu Server
Code:sudo apt-get install libavahi-compat-libdnssd-dev git delete nodes if installed already sudo apt-get purge nodejs npm curl -sL https://deb.nodesource.com/setup_0.12 | sudo bash - sudo apt-get install -y nodejs npm --version 2.11.3 node --version v0.12.7 git clone https://github.com/nfarina/homebridge.git cd homebridge npm update npm install
Code:{ "description": "This is an example configuration file with all supported devices. You can use this as a template for creating your own configuration file containing devices you actually own.", "platforms": [ { "platform" : "Nest", "name" : "Nest", "username" : "nest", "password" : "nest" } ], "accessories": [ { "accessory": "Http", "name": "Desk Light", "on_url": "http://192.168.0.41:8001/JSON?request=controldevicebyvalue&ref=84&value=99", "off_url": "http://192.168.0.41:8001/JSON?request=controldevicebyvalue&ref=84&value=0", "brightness_url": "http://192.168.0.41:8001/JSON?request=controldevicebyvalue&ref=84&value=%b", "http_method": "GET" }, { "accessory": "Http", "name": "Office Lights", "on_url": "http://192.168.0.41:8001/JSON?request=controldevicebyvalue&ref=100&value=255", "off_url": "http://192.168.0.41:8001/JSON?request=controldevicebyvalue&ref=100&value=0", "brightness_url": "http://192.168.0.41:8001/JSON?request=controldevicebyvalue&ref=100&value=255", "http_method": "GET" }, { "accessory": "Http", "name": "Kitchen Lights", "on_url": "http://192.168.0.41:8001/JSON?request=controldevicebyvalue&ref=75&value=255", "off_url": "http://192.168.0.41:8001/JSON?request=controldevicebyvalue&ref=75&value=0", "brightness_url": "http://192.168.0.41:8001/JSON?request=controldevicebyvalue&ref=75&value=255", "http_method": "GET" }, { "accessory": "Http", "name": "Dining Room Lights", "on_url": "http://192.168.0.41:8001/JSON?request=controldevicebyvalue&ref=101&value=255", "off_url": "http://192.168.0.41:8001/JSON?request=controldevicebyvalue&ref=101&value=0", "brightness_url": "http://192.168.0.41:8001/JSON?request=controldevicebyvalue&ref=101&value=255", "http_method": "GET" }, { "accessory": "Http", "name": "Living Room Lights", "on_url": "http://192.168.0.41:8001/JSON?request=controldevicebyvalue&ref=82&value=99", "off_url": "http://192.168.0.41:8001/JSON?request=controldevicebyvalue&ref=82&value=0", "brightness_url": "http://192.168.0.41:8001/JSON?request=controldevicebyvalue&ref=82&value=%b", "http_method": "GET" } ] }
Originally posted by tommyd75 View PostDoes this method give you status of the device, like a thermostat temp, or if a device is on or off where it would show the temp on the iOS device app?
No you can't. I have a nest though so it can tell you the status of that using the nest platform...
Originally posted by madmax View PostThe Elgato Eve is a much better app. Thanks for that tip.
I wonder if HS is planning on native home kit integration? It'd kind of kill off their hstouch app though.
I would say no. They would have to have a hardware device, perhaps the z-net to include a chip for homekit. Sounds like it may make things more expensive. http://www.eetimes.com/document.asp?doc_id=1327267
I'm working on a package to run Homebridge on Windows (because most HSPRO installs are on Windows). Then you have no need to run another box (raspberry) for Homebridge.
I've a working situation in my test environment and will do some tests on my production installation. If I get it stable enough I will share my results!
Originally posted by ewillems View PostI'm working on a package to run Homebridge on Windows (because most HSPRO installs are on Windows). Then you have no need to run another box (raspberry) for Homebridge.
As I'm based in the Netherlands too, please let me know if I can help beta test. I like your (windows based) approach and I'm very interested in integrating HS with Homekit.
Thanks..Regards,
Rien du Pre
The Netherlands
Using:
Plugin's:
RFXCOM, mcsMQTT, Z-Wave
Ewillems,
I am also located in the Netherlands and happy to help and test. I was also experimenting with siri proxy
regards
BartRegards Bart
Win7 64Bit on Intel NUCI7 with SSD
HSPRO 3.
Devices; 1370 Events; 691
Jon00 Scripts, JowHue, HSTouch, Plugwise, Z-wave, Ultranetatmo, Ultracam, PHlocation, BLUSBUIRT, MeiHarmony, Buienradar, MEiUnifi Pushover 3P, Random, Nest HSPhone and Blueiris
Visonic Powermax Alarm System (HS3) Interface: http://www.domoticaforum.eu/viewtopic.php?f=68&t=11129
im also in the netherlands , and im ready to help if neededPreferred -> Jon's Plugins, Pushover, Phlocation, Easy-trigger,
HS3Pro 4.1.14.0 on windows 10 enterprise X64 on hp quadcore laptop 8 GB.
