Originally posted by lakemirror
View Post
iTunes DAAP plugin now works with HSTouch Media API, finally!
Spud, I'm noticing delays when selecting the next track. I'm using the latest version of HSTouch for Android (1.0.137). Album art sometimes doesn't load. Although, everything looks good in the web player. What causes this?
Code:Jan-30 4:01:00 PM iTunesDAAP INFO FetchCover: The operation has timed out Jan-30 4:00:43 PM iTunesDAAP ERROR The operation has timed out Jan-30 4:00:03 PM iTunesDAAP ERROR The operation has timed out Jan-30 3:59:53 PM Z-Wave Device: Security Kitchen Motion Sensor Set to Off/Closed/No Motion Jan-30 3:59:51 PM iTunesDAAP ERROR The operation has timed out Jan-30 3:59:36 PM iTunesDAAP ERROR The operation has timed out Jan-30 3:59:21 PM Z-Wave Device: Security Lower Passage Morion Sensor Binary Set to Off/Closed/No Motion Jan-30 3:59:15 PM HSTouch Server Found music plugin: iTunesDAAP
Well it's good to have a working media player again. It's not perfect, but way better than any other option I've tried. My biggest issue is that I usually pick music by artist. itunes or HSTOUCH seems to list the music by contributing artist. So for instance with Daft Punk Random Access Memories, you end up with 5 different Daft punk listings, each containing a song or two from the album.
I'm attaching the design of one of my touch screens for media player inspiration. What is shown is the player with the media selector flyout open.
The flyout is opened by clicking the button with the music note on it.HomeSeer Version: HS3 Pro Edition
Operating System: Microsoft Windows 10 Pro
Processor Type and Speed: i7 - 3.26 GHz
Total Physical Memory: 16Gig
Plugins: BlBackup | EasyTrigger | FitbitSeer | HSTouchServer | Insteon | WeatherXML
Originally posted by codemonkey View PostWell it's good to have a working media player again. It's not perfect, but way better than any other option I've tried. My biggest issue is that I usually pick music by artist. itunes or HSTOUCH seems to list the music by contributing artist. So for instance with Daft Punk Random Access Memories, you end up with 5 different Daft punk listings, each containing a song or two from the album.
Regarding the problem of listing music by contributing artist, this is due to the way the Artist tag is filled in your mp3 files. I have this same daft punk album in my library and doesn't have this problem.
To fix it, from iTunes select all tracks from this album, right click/ get info, and change the artist name to "Daft Punk"
Thank you, and also Thanks for pointing me in the correct direction for iTunes. Thats got it fixed once I realized that the changes do not show up until you cycle the plugin.
TonyHomeSeer Version: HS3 Pro Edition
I've now have my first instance of iTunes DAAP plugin working great with the media api and HSTouch.
However I have multiple instances of iTunes DAAP plugin working controlling a few instances of iTunes. However I can't seem to figure out how to configure HSTouch to recognize those additional instances of the plugin as seperate music sources in HSTouch. For example I am trying to set up an HSTouch page to use the "music selector element" however when I go to set the properties for this element, I only have one music source to choose from. (Source 1.1 which is my original instance of the iTunes DAAP plugin) How can I get more than the Source 1.1 to show up as options in HSTouch?
Sorry for posting on two threads, but I think this applies to both and I'm hoping someone can answer the question.
Originally posted by maui917 View PostI've now have my first instance of iTunes DAAP plugin working great with the media api and HSTouch.
Originally posted by maui917 View PostJust thought I would bump this thread and see if you have heard anything back from the Homeseer team on the multiple music sources question.
I will try to ask again
iTunes DAAP HSTouch list box on iOs
Spud,
I am assuming this is in HS3 issue and not the plugin but the music selector does not work correctly when tied to a list box is HSTouch on iOS. I have been doing a lot of testing and think I have it narrowed down. When a selection only only has one item, it is not displayed. If a selection has multiple items, it will display them. Any help?
Originally posted by spud View Postdo you have the same problem when you test with the windows HSTouch client that you can launch from the Designer?
