Go Back   HomeSeer Message Board > Irrigation Plug-ins > Irrigation Discussion > EZFlora Insteon Irrigation Controller Plug-in
EZFlora Insteon Irrigation Controller Plug-in Discussions of Adam Telford's EZFlora Insteon Irrigation Controller Plug-in
Old October 1st, 2017, 08:59 PM
field888 field888 is offline
Can't delete device
I had the controller & plug-in installed and running for a few years, then removed the controller and PI last spring in anticipation of a move. Today, I re-installed the PI and controller. I was able to view the valve and program parameters in the controller from the PI but the devices weren't populated on the device manager. I then tried to remove/re-install the device but was only able to add the identical device. Now the device is populated in DM, but I can't delete the other device. I check the device, select 'delete device' but nothing happens.
Old October 2nd, 2017, 10:08 AM
hurry4it hurry4it is offline
I'm guessing that there is an issue in the EZFlora.ini file that is causing this. Please post a copy of your EZFlora.ini file so I can determine if this is the source of the problem.
Adam
Old October 2nd, 2017, 10:57 AM
Adam,
Early this AM, I factory reset the controller, removed the PI, deleted the .ini file, then re-installed the PI and configured the controller from scratch and all is ok. Thanks.
Doug
Old October 3rd, 2017, 08:56 AM
Spoke too soon. I hid unused valves & programs 5-8, and this is what I have now. What did I do wrong? ini file is attached.
File Type: txt EZFlora.txt (306 Bytes, 4 views)
Old October 3rd, 2017, 09:54 AM
Glad you were able to get it working again. Deleting the PI will not automatically delete the devices associated with it so you will need to manually delete them.
Let me know if you run into any problems,
Adam
Old October 3rd, 2017, 10:32 AM
Adam,
Not sure what you mean by manually deleting a device, there is only the one device now in the config page.
Old October 3rd, 2017, 11:26 PM
On the device management page you should be able to delete each individual device (ie zone 1, zone 2, etc.). The plugin isn't aware of these devices since it was deleted and reinstalled, so the remaining devices from the previous install need to be deleted manually from the device page.
Adam
Old October 3rd, 2017, 11:29 PM
Will do, thanks much,
Doug
Cant delete a device Bestgear HS2 / HSPRO 5 November 15th, 2006 04:48 PM
Can't delete device Wazoo HS2 / HSPRO 2 October 4th, 2006 11:12 AM
can't delete a device mosleyh HS2 / HSPRO 4 March 24th, 2006 01:38 PM
Why Does Delete Device Delete Multi-Device Event Actions? plfinch Insteon Plug-in (Mark Sandler) 3 February 1st, 2006 11:35 PM
What happens when you delete a device? David Programming with HomeSeer 3 February 21st, 2002 05:34 PM
