Spurious signals...
I suppose it is a sensor that transmits wrong data.
The plug-in does not have a problem, it only translates the received data.
Remove the battery from the wrong sensor and check if the problem still exists.
If no false data received it is this sensor. If still false data received it must be another sensor.
Solved.. in a real "Duh" moment, but...
Thanks much for the response Bert, I believe I did find my problem, late yesterday afternoon. It turns out, ALL the events for my DS10s (and MS14 motion detectors) were/are set to trigger when "This device had its value set to..." instead of "This device changes and becomes..." (see image below). I am not sure why I ever set them that way (getting old, bad memory), but I did.
IMAGE:
I currently have MS14 motion detector in my hall that turns on a light. Sometime ago, I noticed a group of successive event triggers to turn the light on. No big deal, but I did set the "Do Not Log" checkbox to reduce log entries. However it does still produce the repeats, turning the light on:
2/18/2018 10:05:55 PM,Device Control,Device: First Floor Office Bevo Light to On (100) by/from: CAPI Control Handler
2/18/2018 10:06:05 PM,Device Control,Device: First Floor Office Bevo Light to On (100) by/from: CAPI Control Handler
2/18/2018 10:06:18 PM,Device Control,Device: First Floor Office Bevo Light to On (100) by/from: CAPI Control Handler
2/18/2018 10:06:24 PM,Device Control,Device: First Floor Office Bevo Light to On (100) by/from: CAPI Control Handler
2/18/2018 10:06:31 PM,Device Control,Device: First Floor Office Bevo Light to On (100) by/from: CAPI Control Handler
Six on's in less than a minute, so I guess the MS14s are still picking up motion, and still sending a signal, and the plugin is tripping the event each time? No multiple signal detection for motion detectors? I guess I will have to set the "Cannot Re-Run for:" checkbox.
Gary
