UPS monitor
    UPS monitor
    Ok.. what are folks using to monitor their UPS's? I thought there was a plugin available... I see that there is a BLUPS plugin from Blade, but seemed to remember there was others.
    Anyone?
    Robert
    APC makes a consumer grade UPS that has Ethernet - web page to setup, and I assume, IP packets (broadcast?) on power failure. I wonder how well it works.
    http://www.apc.com/resource/include/...otal_watts=200
    I wish they had one larger than 500VA for consumers.
    $120 or less...
    http://www.newegg.com/Product/Produc...0BACK-UPS%20HS
      Anyone?
      Robert
      Free HS Plugin for UPS unit:
      http://www.tenholder.net/tenWare2/tenHsPower
      tenholde
      tenholde
        Apcupsd
        Look at http://www.apcupsd.com/
        Or search the forum over here for apcupsd, it's a perfect program on you can easy use it in HS with Jon00 plugin.
        Supports serial and USB
          Lang - serial or USB?
          ~Bill
            I have a USB attached UPS. There is a small issue in that my UPS is a Tripplite and not an APC - which seems to be the defacto standard...
            The Tripplite software works fine - just that I cannot get to the java-based application from outside despite having the proper port opened. It does do the shutdown accordingly once the battery gets low. I figure this can be done with HS and HS plugin as well as tracking of power hits. Two of which I am considering are Blade's BLUPS and now tensHSPower. Again, I am running Windows 2000 server and not XP.
            Robert
