Originally posted by ScottRennie
View Post
Installing the IP THermostat plugin
Not at this time, because I have to troubleshoot the code in Visual Studio. Again, soon I will dive deeper into this to find the difference between my system and the ones who are failing.Regards,
Rien du Pre
The Netherlands
Using:
Plugin's:
RFXCOM, mcsMQTT, Z-Wave
Cheers
Scott
To everyone who is experiencing the Honeywell issues with the IPthermostat plugin, please do the following procedure for me:
- Open webbrowser on your HS3 machine and go to the following URL https://rs.alarmnet.com/TotalConnect...ST-api-Session
- Select the blue "Test API" button
- Fill in the following information:
"username": "Your Honeywell user account",
"password": "Your Honeywell password",
"applicationId": "91db1612-73fd-4500-91b2-e63b069b185c"
- Select the "Send request" button
- Let me know the outcome(Response).
ThanksRegards,
Rien du Pre
The Netherlands
Using:
Plugin's:
The IPThermostat plugin has been updated and should now fix the issues with the Honeywell EvoHome thermostats (Finally)
It was a real struglle to find the problem, because I didn't had the issue in my environment.
It was a NewtonSoft.Json issues which now has been addressed.
The update includes also support for the Plugwise ANNA thermostat.
Have fun !!Regards,
Rien du Pre
The Netherlands
Using:
Plugin's:
Hi Rien
So I have installed the latest version, enabled it, set the details for the EvoHome login and all looks like it is working in the logs in that I can see the login working and all my details being returned.
Where I am a little confused is should all the devices be created automatically as i am not seeing anything in the DEvice management section showing up.
Here's a couple of screen shots for you:
Current Date/Time: 22/10/2015 19:36:52
HomeSeer Version: HS3 Pro Edition 3.0.0.208
Operating System: Microsoft Windows 7 Enterprise - Work Station
System Uptime: 0 Days 0 Hours 30 Minutes 40 Seconds
IP Address: 192.168.0.15
Number of Devices: 108
Number of Events: 12
Enabled Plug-Ins
3.0.0.75: HSTouch Server
3.4.0.0: IPThermostat
30.0.0.29: RFXCOM
3.0.0.21: Sonos
Also
I only have a couple of days grace left on the plug-in since I installed it last time - is it possible to extend the trial period?
Cheers
Scott
Originally posted by ScottRennie View PostHi Rien - I have the same issue...
Also
Cheers
Scott
Can you do the following for me?
- Check if the file Newtonsoft.Json.dll is in the <homeseer>/bin/IPThermostat directory
- Check if the file Newtonsoft.Json.dll also exist in the homeseer root directory
- If there is a copy in the root too, please try to rename it. If this fails it is in use by another process, please tell me which process
- If it succeeds, please restart Homeseer and check if the plug is working now and delete the renamed file from the Homeseer root
RienRegards,
Rien du Pre
The Netherlands
Using:
Plugin's:
Hi Rien
Check if the file Newtonsoft.Json.dll is in the /bin/IPThermostat directory - Yes
Check if the file Newtonsoft.Json.dll also exist in the homeseer root directory - Yes
If there is a copy in the root too, please try to rename it. If this fails it is in use by another process, please tell me which process - renames OK
... and it's working.... I am delighted...!!!
As you can see from the screen shot, there is only a profile for one device and no local temps - what devices are set up?
Scott
@Rien - I'm still having problems with no devices showing up. Sent you an email this morning with logs etc, would be grateful for some help/suggestions on resolving this issue please as I've tried uninstalling the Plug-in, restarting HS and PC and reinstalling Plug-in but nothing seems to be working at the moment.
@Scott - Scott I assume the image of each of your heating zones is showing up in the Devices (Home) section of HS3, they were created automatically by the Plug-in and I'm not missing something, or should be looking elsewhere for the Zones/Devices.
Rob.
Originally posted by robw View Post@Rien - I'm still having problems with no devices showing up. Sent you an email this morning with logs etc, would be grateful for some help/suggestions on resolving this issue please as I've tried uninstalling the Plug-in, restarting HS and PC and reinstalling Plug-in but nothing seems to be working at the moment.
Rob.
Yes, they just appeared in the Home Tab with no Type. I don't know why only one device has a profile but it looks good so far...
Scott
