Hi Blade,
I still seem to be having problems getting the plugin to connect to the amp,
I ran the macro today which includes starting the amp which it didn't, so I start the amp manually, and proceeded to use it and after 3 hours the amp still hadn't connect, so I tried the connect command which didn't do what I was hopping, the only way to get my amp to connect was to reset the plugin which I did and the amp then connected and was controllable within seconds.
Is it possible to roll back the plugin or perhaps totally remove and start again to see if this help, any ideas would be appreciated, I have now started the debug though I don't think it will help because I don't think the plugin is aware that it is not connect.
I have check the network settings on the amp and everything seem fine and because the amp connects directly after the plugin is restart seem to indicate the problem is else where, but not sure where
****Update ******
Hi blade,
Did a test this morning and after being powered off all night switched the power on this morning and the plugin switch the amp on OK after around 30 seconds, so not sure what what's causing my issues, but will keep an eye on thing,
****Update ******
Hi blade,
