I've got a strange issue going on that I can't figure out.
I was setting up a way to restore devices to their last value. I use ET to save the devices value whenever it's changed with some exceptions that I'm still working out. The problem is that when I set the last value device with the current value another device also changes that's not even being referenced.
So, If I change the "Fan Light" to a given value the "Left Desk" light will also change to that same value. I have the same thing happens for the "Files Light" and it also changes the "Left Desk" level. Both of these events are the same except for the devices being used. I know it's happening in the saving event as I can execute it manually and get the same result.
I also created a manual test event that only did the copy and it also effects the other light. Somehow Everytime ET does a copy between those two devices the anther device get changed.
In fact it doesn't seem to matter what devices you copy from to that one light also gets changed. I've even tries rebutting and that doesn't fix it.
I'm at a loss to understand this one.
Here are the screen shots for the devices, event and the log. My current plugin are in my sig.
