Sliders on listbox not working anymore?
    I've followed the tips on the forum, and I've copied the way I did it before.
    Like this:
    Originally posted by macromark View Post
    Add a slider next to your event list box and set the "ActionsWhenSelectionChanged" to "Adjust an Elements Level Up" for the "Events List Box" with an increment of "1". Now, when you slide the slider, the event list will scroll. Alternately, you can simply add an "up" button and "down" button instead of the slider and use the same comman but change the increment "up" and "down" to match the number of events displayed at once in the list box.
    However, it is not working anymore...
    Which client, Windows?
    Like this:
      Yes.
      And my old sliders work. I just can't create new (functional) sliders!
        Now you lost me. What do you mean you cannot create new sliders? I just tried the "standard 800x480.xml" config and the sliders there work fine controlling the list box.
        What type of list box are you trying to scroll?
        Yes.
          Yeah, it's confusing for me too. Existing sliders work. New sliders don't...
          When I try to set up a new one (using the your description, see first post) the list does not respond. It just doesen't scroll at all.
            Is the list box set as an events browser? What is in the list?
              The lists are:
              - Device Browser
              - Event Browser
              - Media Selector (WMP)
              - Current Playlist (WMP)
                Just tried a new project and worked fine, here are my steps:
                Create a new project, add a list box
                Use status association and associated with "Media Player Music Selector"
                Add a slider to the project
                Select the actions for the slider and added an Element action to "Adjust an elements level down", selected the listbox as the element, then set the value to 0.
                Saved the project and ran it, the slider adjusts the contents of the list box.
                The lists are:
                - Device Browser
                - Event Browser
