I have the latest Android client. I use HSTouch actions in events to show a screen on top on my Android clients when there is audio or motion in the babys room.
Currently the event loads the screen, waits 30 seconds and then simulates a button press that closes that screen. This all works fine.
What I am left with is what I believe is a bug. The previously loaded screen that was active before my popup window showed up no longer updates device status from status tracking. Changing pages and then switching back causes devices to start updating again.
A work around (haven't tested yet) would be to add an additional hstouch action that loads a screen by itself however it's not ideal. Ultimately there should be some logic that "activated the screen" that was under once the popup screen closes.
Any one else see this behavior, if so I will log a bug
