Hi Mark
i have been away for the last several months as we moved. i had lots of things to take care of before I could get back into my HomeSeer project at the new house. Today I added a new 2472DWH receptacle. The software has added it and I can control the new device from HomeSeer.
When I try to reference the new device in an Event, I see a message which states "Use 'clear' in the Set Display Field to CLEAR the current device string setting". That message is shown when my Event is trying to control a device. I am not sure where to go to CLEAR the field. Can you point me in the right direction?
Secondly, I am getting the following error in my Startup log. Are these issues related? What do you suggest that I should do to clear things up?
Brian
Insteon Plug-in Error Log Generated 9/26/2017 12:10:17 PM
-----------*Error Message*----------------
Error: Error in CreateDevices: Device 9: Object reference not set to an instance of an object. -- Details System.NullReferenceException: Object reference not set to an instance of an object.
at HSPI_Insteon.hspiAPI.HSAPI.CreateDevices(Boolean ReloadTables) -- 9/26/2017 12:10:17 PM
--------*Initialization Log*--------------
9/13/2017 9:01:01 AM - Host System: () 3.0.0.357
9/13/2017 9:01:01 AM - Plugin HSPI_Insteon.exe version: 3.0.6.0
9/13/2017 9:01:01 AM - Insteon Support library (Insteon.dll) version: 1.0.6.0
9/13/2017 9:01:01 AM - RegisterCallback Completed
9/13/2017 9:01:01 AM - Enter InitIO
9/13/2017 9:01:01 AM - Enter InitPlugin
9/13/2017 9:01:01 AM - Global initialization of plug-in required, starting up.
9/13/2017 9:01:01 AM - Initializing Insteon hardware interface...
9/13/2017 9:01:01 AM - In ProcessRawReceiveThread
9/13/2017 9:01:01 AM - Initializing Interface...
9/13/2017 9:01:01 AM - In PLMBuffer_ProcessBufferThread
9/13/2017 9:01:02 AM - Sending command 02 60 to Interface, (Expecting 6 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
9/13/2017 9:01:02 AM - ..Got Interface Response 02 60 33 E3 4C 03 15 9E 06
9/13/2017 9:01:03 AM - ..Got Interface Response 02 60 33 E3 4C 03 15 9E 06
9/13/2017 9:01:03 AM - RF PLM contacted on COM3 with an Insteon address of 33.E3.4C and firmware version 9E
9/13/2017 9:01:03 AM - ResourceManager::RequestExclusive for Resource 1
9/13/2017 9:01:03 AM - ResourceManager::RequestExclusive acquired for Resource 1
9/13/2017 9:01:03 AM - Sending command 02 6B 48 to RF PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
9/13/2017 9:01:04 AM - ..Got RF PLM Response 02 6B 48 06
9/13/2017 9:01:04 AM - ResourceManager::ReleaseExclusive for Resource 1
9/13/2017 9:01:04 AM - Insteon hardware interface initialized.
9/13/2017 9:01:04 AM - I/O (Insteon Protocol) Interface Initializing...
9/13/2017 9:01:04 AM - In TransmitMessageThread
9/13/2017 9:01:05 AM - Scheduled polling enabled.
9/13/2017 9:01:05 AM - In CreateDevices
9/13/2017 9:01:05 AM - Scheduled polling temporarily stopped.
9/13/2017 9:01:05 AM - Reloading 7 Insteon device information tables...
9/13/2017 9:01:05 AM - 17 Matching HS device records were found and updated for the Insteon device database.
9/13/2017 9:01:05 AM - 0 matching HS device records were found and updated for the Insteon group database.
9/13/2017 9:01:05 AM - Scheduled polling resumed.
9/13/2017 9:01:05 AM - Exit CreateDevices
9/13/2017 9:01:05 AM - I/O(Insteon Protocol) Interface Initialized.
9/13/2017 9:01:05 AM - Waiting to initialize External Devices...
9/13/2017 9:01:05 AM - Exit InitPlugin
Brian
