Go Back   HomeSeer Message Board > 3rd Party Plug-Ins/Scripts > Plug-ins by Author > Click Here for List of Author Forums > Blade Plug-Ins > BLML2HS (3P)
BLML2HS (3P) Discussion of Blade's BLM2HS Plug-in
Old November 2nd, 2015, 01:12 PM
pyspilf's Avatar
pyspilf pyspilf is offline
Plugin status variable
I was looking for a variable in MLServer that indicates the state of the BLML2HS plugin (i.e. if it is connected to HS or not) but couldn't find it.
Alternatively, can I get the status of the interface in HS? Then I can set a virtual device with the value and send it over.
I would like to display the state of the interface on my touchscreens using ML. I use this to make sure the information I am seeing is up to date and not static (that happens if the plugin disconnects)
Any suggestion?
HS3 Pro Edition 3.0.0.409| Plug-Ins Enabled: Sonos 3.1.0.22, RFXCOM 30.0.0.36, X10 3.0.0.36, IPThermostat 3.4.5.0, Pushover 3P 0.0.0.37, Blue-Iris 3.1.1.24385, Z-Wave 3.0.1.162, BLML2HS 2.0.28.0 | Win 7 32-bit | Intel Atom D2550 @ 1.86GHz 4GB RAM
Old November 2nd, 2015, 01:23 PM
Blade's Avatar
Blade Blade is offline
There should be a variable for this. I will have to look and see the exact name of it as it has been a while since I looked at it
Cheers,
Bob
Old November 2nd, 2015, 05:53 PM
Blade's Avatar
You should be able to use the following variable
blml2hs_connection_string (Connected/Disconnected)
blml2hs_connection_status (On/Off)
Old November 3rd, 2015, 03:48 AM
pyspilf's Avatar
Thanks a lot Bob, found it. Would be great if it made it into a revision of the help document at some stage. Also, I noticed while using the help file yesterday that some sections reference ML2HS as opposed to BLML2HS in the examples. No big deal, just wanted to let you know.
Cheers
Old November 3rd, 2015, 06:54 AM
Blade's Avatar
Yea that was the old name of the MLServer plugin. I will go through and update the references
Changing status variable codes simonmason JV Caddx Plug-In 0 September 7th, 2014 08:13 AM
mcsxap not getting Ocelot variable status jcc xAP Discussions 1 May 23rd, 2014 12:49 PM
Problem with variable sensor status with 54 wkomorow HomeTroller Zee 3 December 28th, 2013 08:26 PM
