Originally posted by alan_smithee
View Post
Thank you very much for all your effort you put into this.
I've installed the new version after I
- removed the device
- disabled the plugin
- removed the ini files
- removed the authentication from the Sony tv
I did not restart the HSserver this time.
This time I also have a WOL button and a empty button but the rest of the buttons are still gone.
I did not turn on debug logging but I got this from the log
When I get home tonight I'll try it on the Windows version and also turn on super debug on the Linux HSserver to capture that log.
2017-03-20 06:21:49 MC Error Error in SendJSONAuthentication for device - KDL-55W809C doing a GetResponse with error = The remote server returned an error: (401) Unauthorized. and Response = {"error":[401,"Unauthorized"],"id":13} 2017-03-20 06:21:45 MC CreateUPnPControllers created an instance of UPnPDeviceController for UPnPDevice = KDL-55W809C 2017-03-20 06:21:45 MC CreateHSServiceDevice created device Remote with HSRef = 886 2017-03-20 06:21:45 MC Error Error in SendJSON for device - KDL-55W809C doing a GetResponse with error = The remote server returned an error: (403) Forbidden. and Response = {"auth_url":{"default":"http:\/\/172.16.148.13:80\/sony\/webauth\/auth_default","tv":"http:\/\/127.0.0.1:80\/sony\/webauth\/auth_tv"},"error":[403,"Forbidden"],"id":3} 2017-03-20 06:21:45 MC Error Error in SendJSON for device - KDL-55W809C doing a GetResponse with error = The remote server returned an error: (403) Forbidden. and Response = {"auth_url":{"default":"http:\/\/172.16.148.13:80\/sony\/webauth\/auth_default","tv":"http:\/\/127.0.0.1:80\/sony\/webauth\/auth_tv"},"error":[403,"Forbidden"],"id":3} 2017-03-20 06:21:44 MC InitIO Called for Instance = 60eb4257-5e32-4859-8fb6-0c2e917e6345 and running on OS = Unix 2017-03-20 06:21:44 Info Plugin MediaController with instance 60eb4257-5e32-4859-8fb6-0c2e917e6345 has connected. IP:127.0.0.1:33990 2017-03-20 06:21:44 MC CreateHSRootDevice: Created device KDL-55W809C with reference 885 2017-03-20 06:21:44 MC CreateHSRootDevice called with DevType = RCR and DeviceName = KDL-55W809C and DeviceUDN = 60eb4257-5e32-4859-8fb6-0c2e917e6345 2017-03-20 06:21:44 MC AddDevicetoHS called with DeviceUDN = 60eb4257-5e32-4859-8fb6-0c2e917e6345 2017-03-20 06:18:42 MC CreateUPnPControllers called but no devices found 2017-03-20 06:17:29 MC Registered SpeakerProxy 2017-03-20 06:17:29 MC FindUPnPDevice - Discovery succeeded: 9 UPnPDevice(s) found. 2017-03-20 06:16:50 MC FindUPnPDevice: Attempting to locate all connected devices. This may take up to 9 seconds. 2017-03-20 06:16:50 HSTouch Server Warning Exception on Value Change callback: Object reference not set to an instance of an object 2017-03-20 06:16:50 MC InitializeUPnPDevices is creating a new Masterdevices with Ref = 884 2017-03-20 06:16:50 MC Warning InitializeUPnPDevices is deleting all existing HS devices 2017-03-20 06:16:49 Plug-In Finished initializing plug-in MediaController 2017-03-20 06:16:49 MC Media Controller Plugin Initialized 2017-03-20 06:16:48 MC InitIO Called for Instance = 2017-03-20 06:16:48 MC InitIO for Instance = found this plugin running on Linux = True 2017-03-20 06:16:48 MC InitIO Called for Instance = and running on OS = Unix 2017-03-20 06:16:48 MC InitIO for Instance = found HS running on Linux = True 2017-03-20 06:16:48 MC InitIO for Instance = found CurrentAppPath = /etc/HomeSeer 2017-03-20 06:16:48 Info Plugin MediaController has connected. IP:127.0.0.1:33906
Dirk
