Just as the title says. I am testing this out (trial) and I added a second user and I can't get the calendars for the second user. It just shows me the list of calendars for the first user. I also do not get an authorization popup for the second user. My guess is that it is using the same credentials as the first user?
Can't show calendar for second user
So Blade asked me to ask this question here since he thinks that someone else had a similar issue and it was fixed on the user's end. I deleted both users and went to add just the second one. It worked, but it shows me the calendars for the other user that is no longer there (Note I deleted both and added only the second back!).
Has anyone else had this issue and know how to resolve it?
Originally posted by sirmeili View PostI thought I would try a complete reinstall of the plugin, but it won't let me uninstall it either. I click the "X" and it just refreshes the screen. No error in the HS logs either as to why.
I'm still at a loss for this.... No matter what I only ever get the calendar list for 1 person even if that user has been deleted from BLGData. It is making it pretty useless for me.
Blade, can you tell me where the options/settings files are stored? I would like to completely uninstall the plugin, but last time I did, the settings were still there after I re-installed.
I think I found the issue and maybe it is Chrome's fault?
It seems once I am "authenticated" with OAuth 2.0 for a user, it will always use that users data. I confirmed this by using the API explorer in the developer console. I cannot, for whatever reason, get it to sent me data from another user once I select a signed in user to "authenticate" with.
This tells me, unless someone can tell me for certain that they have it working, that it won't work with more than 1 user.
also, the "Reset Authentication" button seems to do absolutely nothing for me. I assumed it would force me to click the "allow" button again, but not the case for me.
This is kinda disappointing because I had lots of uses for this specific plugin.
