I have had slow x10 command reponse. The commands always make it but are slower than dirt at times. 10 to 30 second delays at times. Figuring it was noise on the line I systematically started unplugging devices all around the house. This did not solve the problem.
Next In I noticed something interesting. When I sent an x10 command as soon as the leveiton phase coupler flickered showing signal activity the x10 device would turn on or off. If the device responded quick, the phase coupler would show signal and flicker quick. If the x10 command was delayed the phase coupler signal indicator would be delayed, and as soon as it flickered the device would respond.
So for instance, x10 command sent from homeseer, 10 seconds pass by showing delay, then bam leviton signal activity blinks and immediately the device turns on. Based on that it seems the delay is coming from homeseer to the CM11a, or the cm11a is sitting there for 10 seconds then sending the signal out.
How do I troublehsoot this? what debugging can I turn on to see if ihmeseer is timing out and retrying/sending commands to the cm11a?
One thing to note is I use a prolific usb to serial converter for my CM11a since I am out of serial ports with the cm11a on com6. Been using this setup for years without issue, but maybe the delay is at the usb to serial converter level.
