I would like to know if it is possible to use an HS3 platform to setup a Z-Wave to MODBUS data gateway. I have Z-Wave devices (t-stats) that need to be viewed and adjusted through a MODBUS user interface.
HS3 as MODBUS Gateway
This should be possible with the plugins and some virtual devices. Can you describe a use case in some more detail? The z-wave plugin is free as part of HS3 and the modbus plugin has a 30 day trial so you can test your scenario before spending.
Gaz
Sent from my iPhone using TapatalkAuthor of Highpeak Plugins | SMS-Gateway Plugin | Blue Iris Plugin | Paradox (Beta) Plugin | Modbus Plugin | Yamaha Plugin
Gaz,
My application would be to integrate about 4 ZWave devices (t-stats) with a commercial building automation system that has a MODBUS RTU network. Points from the t-stats such as setpoint and temperature need to be mapped over to MODBUS registers so that they show up on the building automation system as MODBUS points. Hopefully, this can be achieved.
Bill
Glad you got it sorted Bill. You can either install a USB device or use an IP to Modbus device and communicate over IP giving a little more flexibility and less power drain in the Pi.
Let me check the USB model I use and I'll let you know
Thanks for the quick reply and info, Gaz. I'm expecting to have to install a driver for whatever USB device I end up getting. I'm not a Linux guy, so I'm not sure how to go about installing driver software into the ZEE device. Are there any guide documents out there regarding device driver installation for the ZEE that you can point me to?
I'm afraid we're outside the scope of the plugin support here as well as my knowledge of the ZEE. I don't run one so I don't want to speculate on something that might let you down.
There are a number of USB to serial devices supported by Raspbian that I'm pretty sure the Zee runs - Google is your friend here.
If your budget will stretch look at the Lantronix IP to Serial (and RS485) devices and you can go pure IP - more costly for sure, but perhaps more reliable and supported in the long run?
Gaz,
Well I decided to go with TCP. My ZEE IP address is 192.168.1.112. I have a Modbus Gateway device on my network set at 192.168.1.113. I configured the PI Modbus Gateway setting with that address, and I get the message "Passed connectivity test to gateway" when I click the Test button, however, the PI remains in the Unreachable state. Any ideas?
Is the gateway 'enabled' on the device configuration screen?
Have you added an register/could devices for the gateway to access and retrieve data from?
Originally posted by beerygaz View PostIs the gateway 'enabled' on the device configuration screen?
I have created 4 registers on the gateway device that I can see and manipulate from another application, so it seems to be communicating. If I understand the gateway product correctly, the data resides in a virtual device address 8, and the 4 holding registers (16 bit) are 1, 3, 5 and 7.
Did you create register devices in HS3 to represent your holding registers at 1,3,5,7? Can you go to the PI config page and enable debug logging / log to file and then mail me the log file in the \logs folder? Gavin at highpeak.co.za
Originally posted by beerygaz View PostDid you create register devices in HS3 to represent your holding registers at 1,3,5,7? Can you go to the PI config page and enable debug logging / log to file and then mail me the log file in the \logs folder? Gavin at highpeak.co.za
I emailed the info you requested to gavin@highpeak.co.za and wanted to check with you to see if you received it.
Bill
