Originally posted by Blade
View Post
Special Tag source= not working
HS3Pro & HS4Pro on Win2012R2
Aeotec, Cooper, Cree, GE/Jasco, Intermatic, LIFX, Fortrezz, OSRAM, RCS, Trane, Zooz
BLBackup, BLGData, BLRussound, BLSpeech, HSTouch, InvisaLink, HSBuddy, IFTTT, JowiHue, NetCAM, PHLocation, Pushover 3P, Random, rnbWeather, UltraLighting3, weatherXML, ZigBee, Z-Wave
I have been seeing zones stay on when they should go off. I can duplicate that pretty much every time. I need to play with some delays. I think the calls are being sent to the Russound too fast and it might be missing some. The devices in BLRussound say they are off but the keypad is on.
I think I need to bundle the commands for a speech action and then perform them at once and see what happens. I will play with this and let you know when I have something to try out.
having/fixing the delay would be good. I have two events that happen every morning and even though I put a delay on one of them, they still sometimes bump into each other and one does not work. and on the speak side, I have to delay the start of the speech or it does not catch the first part of the first sentence. So the speaking starts before the unit fully turns on.HS3Pro & HS4Pro on Win2012R2
Originally posted by S-F View Post@Jobee, what Russound system do you have? I have a CAA and don't see these issues even though I make great use of BLSpeech.
Originally posted by S-F View Post@Jobee, what Russound system do you have? I have a CAA and don't see these issues even though I make great use of BLSpeech.HS3Pro & HS4Pro on Win2012R2
Yes I am seeing this as well with my 2 CAV66 units.
I will have to narrow this down to see what is causing it. I have some ideas to get around it. I just need time to actually sit down and work on it. I got a lot of the garage cleaned up over the weekend so I should be able to look at this more this week
Hi Blade,
One other item. When my server has to reboot and comes back up, all my zone/speaker associations are gone. This has happened the last 3 reboots. Each time I have to go into each speaker and re-select the zones.
Let me know if you need something to reproduce this.
MichaelHS3Pro & HS4Pro on Win2012R2
Michael
I've noticed this as well but thought maybe it was the OS and not the plugin. I have to restart the computer to get it to come back. Doesn't happen often though.
Great news Bob. Can't wait to test. Just as a side note, over the last week or so some of my items have been doubling up. So they play once when they are assigned to but then they play again about 10 seconds later out of the blue. There is no rhyme or reason for it and I have not been able to make it happen on cue.
Originally posted by Jobee View PostGreat news Bob. Can't wait to test. Just as a side note, over the last week or so some of my items have been doubling up. So they play once when they are assigned to but then they play again about 10 seconds later out of the blue. There is no rhyme or reason for it and I have not been able to make it happen on cue.
Michael
It's possible you have another speak proxy running they another plugin. If you recently installed or messed with another plugin see if the option is enabled.
Michael
Sent from my XT1585 using Tapatalk
