device value from summary data
    I'm testing the plugin controlling and charting the temperature of my radiators.
    Every day I check the minimum, maximum and average value.
    The average temperature can say me how much the radiator was hot in the day and I can calculate the cost for my home clima.
    Is it possible to extrapolate the average temperature value and put it in a device as value? Every night I can create a database with daily "average temperature" for each of my radiator.
    Cris
    What about a script running every night that calculate average and store that in a virtual device. Then chart that virtual device
      Plugin report already daily average. What I want is a way to pick this value and put it into device value :-)
        Ok, I think that is what I also answered on?
        You can use a script to set that value to your desired device.
          Yes, you are right.
          My problem is how I can calculate the average! The plugin already generate the average, I don't know where I can find this value.
          Of course, then with a script a can pass the valute to a device (SetDeviceValue...)
          Plugin elaborate the average but I need to find this value
          Other solution could be to have a script taht every 5 minutes read the temp value and store the data, in the night read all data and calculate the average.
          But if I already have the value in the plugin I'd like to use this data.
            I'll definitely consider this in a future release. The raw data is all there in the SQLite database, so it's a matter of querying it correctly. Which means there needs to be a "group by" clause, and that will require additional user interface design to allow you to choose the intervals, etc.
              Great!
