I'm using a Hometroller ZEE S2 controller. It only has USB ports. I called Homeseer support and they suggested I buy their Trendnet USB to serial converter to connect to my Russound Cav6.6. But since the ZEE is a Linux device what port do I enter into the Russound Plugin? I know Linux ports are something like /dev/xxx instead of COMn like on a PC. Homeseer supposrt said I needed to contact you for the info since it's not their plugin.
Thanks in advance for any help you may be able to provide.
