Go Back   HomeSeer Message Board > HomeSeer Products & Services > HomeSeer General Discussion Area
HomeSeer General Discussion Area General discussion about HomeSeer that does not fall into any other category or are not specific to 1.x or 2.x versions of HomeSeer.
Old April 16th, 2018, 08:39 AM
RebelT RebelT is offline
Seer
ZWave low voltage relay
Hi everyone -
I have an idea for a project I would like to do, but it will require a controllable Zwave low voltage relay.
I am familiar with the Fibaro RGBW controller, but are there perhaps other, simpler devices that will do what I'm looking for? I just need a low voltage powered relay that will trigger a dry contact.
Old April 16th, 2018, 08:48 AM
ServiceXp's Avatar
ServiceXp ServiceXp is online now
Seer Master
What do you consider low voltage, and what will the load be?
RJ_Make On YouTube
Old April 16th, 2018, 09:48 AM
langenet's Avatar
langenet langenet is offline
OverSeer
The Fortrezz MIMOLite Zwave Input Output Module is your friend...
Robert
HS3PRO 3.0.0.435 as a Fire Daemon service, Windows 2016 Server Std Intel Core i5 PC HTPC Slim SFF 4GB, 120GB SSD drive, WLG800, RFXCom, TI103,NetCam, UltraNetcam3, BLBackup, CurrentCost 3P Rain8Net, MCsSprinker, HSTouch, Ademco Security plugin/AD2USB, various Oregon Scientific temp/humidity sensors, Z-Net, Zsmoke, Aeron Labs micro switches, Amazon Echo Dot, WS+, WD+ ... on and on.
Seer
Quote:
Low voltage is 12vdc or 24vdc (either is acceptable).
There will be no load as I only need to trigger a dry contact. The load will be controlled by a separate power supply, which I will use the dry contact to trigger.
Old April 16th, 2018, 09:51 AM
Seer
Quote:
Originally Posted by langenet View Post
The Z-Wave Minimote is your friend...
Robert
Hi Robert --
Is this the device you're referring to?
https://www.123securityproducts.com/...hoCu-MQAvD_BwE
If so, can you explain how this could be helpful in my scenario?
Old April 16th, 2018, 10:05 AM
langenet's Avatar
OverSeer
Sorry.. mis-fired neurons.. I meant the fortrezz-mimolite-zwave-input-output-module.
https://www.aartech.ca/mimolite/fort...ut-module.html
They used to sell them here - couldn't find it when I looked.
I use this to control my gas fireplace and it works great!
Robert
Old April 16th, 2018, 10:32 AM
Seer
Robert
Thanks Robert! I'm glad to know that I'm not crazy for being confused at my original link!
That device looks like it would do the trick, for sure. However, for that price (~$70 USD), I could get another Fibaro RGBW controller and use it, and it would give me more options as well.
I am a little surprised that there aren't more options out there to do this. I would have expected this to be a pretty common occurrence, but perhaps not? I'm wondering if maybe the alarm world has a few more options...
Old April 16th, 2018, 10:50 AM
Jon798 Jon798 is offline
Seer Deluxe
Do Qubino sell in the US? They have a dry-contact relay module that can be powered by 110V AC or 24-20V DC:
http://qubino.com/products/flush-1d-relay/
(No affiliation; I've used a few of their modules and they are ok. Generally similar to Fibaro in form and function.)
Cheers,
Jon.
Old April 16th, 2018, 11:28 AM
ksum ksum is offline
Seer Deluxe
I have a Linear Isolated Contact Fixture Module which is apparently discontinued according to the Linear site but the GoControl site doesn't confirm this and both sites show GoControl on the unit, but a web search does show many z-wave contact closure units. Some in the 30.00 range.
I use the unit to open/close my garage door by running an event which turns it on, waits a second and then turns it off. It has house line power running the unit and connections for the controlled wiring.
Karl S
HS3Pro on Windows 10
96 Devices
54 Z-Wave Nodes
37 Events
HSTouch Clients: 3 Android, 1 iOS
Google Home: 3 Mini units
Old April 16th, 2018, 12:28 PM
Seer
Cheers,
Jon.
Hey Jon,
Yes, it does look like Qubino is available in the US, and this looks like a great option! Approx 40% less expensive than the Fibaro, but looks to be perfectly suited for what I'm looking for.
Thank you! I will keep looking, but this is the frontrunner right now!
Old April 16th, 2018, 12:30 PM
Seer
Karl, this is indeed a dry contact relay, but it is one that requires line voltage (120vac/240vac) instead of low voltage (12vdc/24vdc).
However, thanks for the recommendation -- I will be starting on a garage door project soon, and this looks like a great start to that!
Old April 16th, 2018, 12:47 PM
Seer Deluxe
The one I use requires Line Voltage to operate but controls a separate connection and could control low voltage. I have it connected to the same connections the push button is on for my garage door opener. I am sure this and others could control low voltage as well. Yes, it is powered by line voltage for the z-wave on/off, but it does not pass that same line through.
If I were doing the garage door today I would use one of the other items available for garage doors. They were not available when I set that up.
HTML code is Off
Z-wave thermostat as wireless low-voltage relay peepisklak General Home Automation Hardware Discussion 3 October 7th, 2012 08:08 AM
Which Zwave relay switch (product inquiry) ArbWare HomeSeer General Discussion Area 2 June 1st, 2009 05:43 PM
Moving to house with Low voltage relay control gregg_johnston General Home Automation Hardware Discussion 12 January 28th, 2006 02:49 PM
How to convert the analog voltage bit # from SECU16 into a voltage value in HS? tross ADI Ocelot 3 September 2nd, 2002 01:48 PM
