Hey Gang-
Well, as you already know, this plugin has been re-coded. I am attaching the latest build as of right now, which is version ***(see below). Please note that as Rich already mentioned, this plugin will not work with your existing devices and events as it is a totally new DLL.
How to Install
That's about it. I will be here to support any problems, and please provide some feedback! If there is something that worked in the old plugin that does not in this one, please let me know.
Latest Version: 2.3.2614.17538
How to Install
- Shut down HomeSeer
- Delete your old plugin. This is an OCX file located in your HomeSeer folder called hspi_rcsserialtherm.ocx. If you skip this step, HomeSeer may become confused by the two plugins.
- Extract the enclosed DLL into your HomeSeer folder.
- Restart HomeSeer. Enable the plugin and set the Com port, and click on the "Config" button to add thermostats.
