Hi Folks:
I have a Venstar T1700 thermostat that I am trying to integrate with HS2. I have the Sage Thermostat Plugin and the Insteon Plugin installed in HS2.
It seems that the T1700 is linked as I can change the heat and cool set points through the plugin, but under the thermostat control tab the temperature always shows as 0 degrees (Thermostat shows 76).
Sorry for my ignorance, but how do I get this set up to report the temperatures to HS2 or to poll the T1700 to get the temperature. I am using this as a replacement for an old X-10 templinc unit. I just need to get the temperature from this thermostat and then trigger events in HS2 based on whether a high or low temperature setpoint has been reached.
Any assistance would be greatly appreciated.
Best regards, Dave Melnyk
