Spud... trying another one of your plugins out :-)
so... per this thread, i'm trying to setup an alert if my hot tub temp goes below 100 degrees.
https://board.homeseer.com/showthrea...=1#post1283524
Somebody recommended this plugin... although after installing the trial, i'm still not sure it can do what a I want, which seems so simple.
per the other thread, i was thinking about using "changes and becomes a custom value or value range"....
In your plugin, i can compare two device values, but what i really want is to compare the device value, and notify me if it goes below a static value i set - in this case 100 degrees?
Also, can this help me (i don't see it) have this so it doesn't continually run the event while the condition is true? I only want to get one email :-)
