Change destination backup folder not working
    I have been using v2.0.37.0 of the plugin backing up to C:\Backup. Recently, to alleviate disk space issues, I went into the options and changed the destination backup folder to D:\Backup.
    After that I started getting errors that C:\Backup cannot be found.
    So I recreated C:\Backup and it runs fine - into C:\Backup.
    I then opened up each of the backup jobs and re-saved them. Same issue.
    I tried creating a new job and it also backed up to C:\Backup and not into D:\Backup.
    For now I am using an external utility to move the backups from C: to D: each day. Is there an ini file I can look at to see why changing the destination backup folder is not working? It shows correctly in all parts of the plugin setup. Thanks.
    The destinatin on the options page is the default one
    In the event you can specify a different destination folder
    Show me a screenshot of your event
    Cheers,
    Bob
      I only have one event calling the routine each night.
      I have included one of the examples - it is backing up the caddx directory to C:\Backup - not D:\Backup as listed.
        Can you expand out your event and attach another screenshot
        Cheers,
        Bob
          A-ha - the directory was wrong in the event - it was set to C:\Backup. I changed that to D:\Backup and all is good in the world. Thanks!
