Originally posted by ve3bwp
View Post
Feature Requests for the Mark Sandler Insteon PLM Plug-In
Mark
HS3 Pro 4.2.19.5
Originally posted by mnsandler View Postin v1.5.3 i added a trigger (called interfaces crashes) to let you know if the plm is having trouble communicating. Have you tried this?
Is there a way to show the PLM as a "Status" device?
Also, would support for the EXIO2x4 #5010D be possible?
#2, I don't have any of the simplehomenet devices so its impossible to add support. I think there is an external script in the forum that should do the basics; a simple search should find it.Mark
HS3 Pro 4.2.19.5
Originally posted by mnsandler View Post#1, yes, but it wouldn't be very useful. The status would either day Online or Offline. Try the trigger and see what you get.
#2, Thanks, I will search
Again thanks for all you do!!
Feature request ... change device characteristics in a script
Apologies if this is already implemented ... if it is, I can't find it.
I'd like to change the backlight level on keypadlincs (and the keyclick on/off) from a script. The idea is to turn the backlight level down at night, and up during the day.
Are there any scripting functions to change the device settings?
Originally posted by firtha View PostApologies if this is already implemented ... if it is, I can't find it.
Hang in there, I'll be working on this over the next few weeks. I've been working on adding support for the next batch of insteon devices I received from SH so i need a little break.Mark
HS3 Pro 4.2.19.5
Originally posted by stevewinick View Postminor request (hopefully). would like to see the flag that controls whether the outlet auto-senses a load with auto-turnon. i'd like to be able to see the state of the flag and change it from the plugin
thanks !
sjwMark
HS3 Pro 4.2.19.5
Thanks!Mark
HS3 Pro 4.2.19.5
here is the whole section:
[Device 54]
DeviceID=18.AE.AF
DeviceName=Kitchen Counter Warmer Outlet - Insteon
DeviceLocation=Kitchen
DeviceType=0208
FirmwareVer=38
DatabaseDelta=6
LinksDownloaded=1
PollingInterval=5
Protocol=2
EEValues=LEDBrightness=0,OpFlags1=34
RecentDatabaseDelta=6
NumLinks=5
Link 1=A2 FE 13 AC A9 FF 1F 01 1
SyncLinkedDevices=1
Link 2=A2 04 14 CC A2 FF 1F 01 2
Link 3=E2 01 14 CC A2 FF 1F 04 3
Link 4=A2 04 15 07 CB FF 1F 01 6
Link 5=E2 01 15 07 CB FF 1F 04 7
TotalInteractions=32
FailedInteractions=0
LastContact=8/1/2011 8:23:53 PM
thanks !!
sjw
Originally posted by stevewinick View Posthere is the whole section:
[Device 54]
DeviceID=18.AE.AF
DeviceType=0208
FirmwareVer=38
DatabaseDelta=6
LinksDownloaded=1
PollingInterval=5
Protocol=2
NumLinks=5
SyncLinkedDevices=1
thanks !!
sjw
Steve, 0208, that's what i thought. I just posted 1.5.6 beta which has the feature you want. Please give it a try and post your comments to the 1.5.6 thread. thanksMark
HS3 Pro 4.2.19.5
FeMan
Mark:
This is a very simple request.
Can you modify the plug-in to use location1 and location2?
All I that is needed is another location box when setting up a new device.
ThanksMark
HS3 Pro 4.2.19.5
FeMan
I have been using Location for location1 and Interface for location2. That tells me basically where in the house and what interface it is on, i.e., X10, X10RF, Zwave, Virtual, Concord Alarm Panel, etc.
When I install a new Insteon device, I get to fill in the device Location, I would like the option of specifiyng Insteon as my interface as Location2.
Originally posted by FeMan View PostI have been using Location for location1 and Interface for location2. That tells me basically where in the house and what interface it is on, i.e., X10, X10RF, Zwave, Virtual, Concord Alarm Panel, etc.
shutdown hs, and add the following to the [config] section of your insteon.ini
DefaultLocation2=Insteon
replace Insteon with your own value
restart hs.
Now, when you create a new device in the plugin, the plugin will automatically assign Insteon to Location2Mark
HS3 Pro 4.2.19.5
