I have updated the first post
BLPlex
Hi Blade,
Thanks for posting the Plug-In. I am unable to get it to function properly. I may have a unique environment.
Notes:
1) I can login to the PI just fine, it Initializes my Plex Server and receives a token.
2) Turning on debugging created a 4.2GB log file in less than 20 minutes which was too large for me to open.
3) My Plex Server is on a different subnet. I turned off Windows Firewall just to see if that was the issue before I created an exception for TCP Port 32400. I am not sure if any of that was necessary or not but the PI is not creating any devices even though the status is "Initialized".
4) Logging Options - Log Plex Server Activity does not stay ticked after PI Restart.
HS3 Pro Version 3.0.0.293 (Windows 10 Pro 64-bit)
Plex Media Server Version 2.7.7 (Windows 10 Pro 64-bit)
BLPlex Plug-in Version 2.0.0.0
Any ideas on where to start with this?
Thanks for your assistance,
-Travis
Very odd... Can u try the following
1. Disable BLPlex
2. Edit hspi_BLPlex.ini and change debugLevel=true and save INI file
3. Re-enable the plugin
4. Let it run until you see the message in the HS log that the service is initialized
5. Turn off debug logging
6. Email me the log zipped directly - blade9123 at gmail dot com
I don't get it working too.
Installed en enabled the plug, configured it and got a token. Enabled debug logging, but the only logging I got is:
aug-11 12:56:31 BLPlex Initialization complete for Plex Media Server
aug-11 12:56:31 BLPlex Initializing Plex Media Server...
aug-11 12:55:39 Plug-In Finished initializing plug-in BLPlex
aug-11 12:55:39 BLPlex start BLPlex plugin has been initialized
aug-11 12:55:38 BLPlex Initialization complete for Plex Media Server
aug-11 12:55:37 BLPlex Initializing Plex Media Server...
aug-11 12:55:37 BLPlex start BLPlex Debug Logging is Enabled!
aug-11 12:55:37 BLPlex start Loaded configuration successfully
aug-11 12:55:37 BLPlex start BLPlex version is: 2.0.0.0
aug-11 12:55:37 BLPlex start Initializing BLPlex...
aug-11 12:55:37 Info Plugin BLPlex has connected. IP:127.0.0.1:49580
No error, no devices, any ideas? Do I need to enable a setting on the plex server ?Regards,
Rien du Pre
The Netherlands
Using:
Plugin's:
RFXCOM, mcsMQTT, Z-Wave
Originally posted by Blade View PostHmmm... I have been running it for months and it is working
Could it be a firewall issue with the port?
Capture a debug log like I stated in the previous post and I can see what is going on
All tough debug logging is on, there is no more logging than I posted.Regards,
Rien du Pre
The Netherlands
Using:
Plugin's:
Originally posted by Blade View PostVery odd... Can u try the following
1. Disable BLPlex
Sent the file per your request.
-Travis
My Plex system is running on a QNAP NAS and after Bob fixed some issues for me it's now running fine.
I have 2 feature requests now: :-)
- Ability to see the last play media title (when the plex client is disconnected, this field is empty)
- Ability to see which movies or TV series are newly added.
Thanks Bob, so far I'm more than happy with it :-)Regards,
Rien du Pre
The Netherlands
Using:
Plugin's:
