PLM has been running fine for three days then this morning HS suddenly can't talk to it.
Here's my log...
9/22/2011 5:55:25 AM X10 Received G5 (Occupancy Sensor Master Bedroom Motion Sensor) G Off
9/22/2011 5:55:25 AM Device Control Command sent to Occupancy Sensor Master Bedroom Motion Sensor: G5 Off Dimval: 0 Data: 0
9/22/2011 5:55:57 AM X10 Received G3 (Occupancy Sensor Garage Motion Sensor) G Preset Dim 15
9/22/2011 5:56:01 AM X10 Received G3 (Occupancy Sensor Garage Motion Sensor) G Off
9/22/2011 5:58:58 AM Insteon ** An error occurred in this plug-in. The details have been written to the log file - C:\Program Files\HomeSeer HS2\Config\Insteon Error Report.Log
9/22/2011 5:58:58 AM Insteon ** To request help with this problem please post this log file to the forum along with a detailed description of what lead to this problem.
9/22/2011 5:58:58 AM Insteon A device attached to the system is not functioning.
9/22/2011 5:58:58 AM Insteon Attempting to restart the RF PLM Interface...
9/22/2011 5:59:03 AM Insteon Attempting to restart the RF PLM Interface...
9/22/2011 5:59:08 AM Insteon Attempting to restart the RF PLM Interface...
9/22/2011 5:59:13 AM Insteon Attempting to restart the RF PLM Interface...
9/22/2011 5:59:18 AM Insteon Attempting to restart the RF PLM Interface...
9/22/2011 5:59:23 AM Insteon Attempting to restart the RF PLM Interface...
9/22/2011 5:59:28 AM Insteon Attempting to restart the RF PLM Interface...
9/22/2011 5:59:33 AM Insteon Attempting to restart the RF PLM Interface...
9/22/2011 5:59:38 AM Insteon Attempting to restart the RF PLM Interface...
Later this morning I tried to manually restart the plug-in...
9/22/2011 9:06:22 AM Plug-In Shutting down generic Plug-In: Insteon
9/22/2011 9:06:50 AM Plug-In Initializing Plug-in: Insteon on COM port 6
9/22/2011 9:06:50 AM Error Initializing interface: Insteon->Could not open COM6 - Access to the port 'COM6' is denied.
9/22/2011 9:06:50 AM Plug-In Finished initializing plug-in Insteon
9/22/2011 9:11:01 AM Plug-In Shutting down generic Plug-In: Insteon
9/22/2011 9:11:01 AM Plug-In Initializing Plug-in: Insteon on COM port 11
9/22/2011 9:11:01 AM Error Initializing interface: Insteon->2nd attempt to global init the plug-in was ignored.
Is this the lock-up problem that's plagued the USB PLM since Smarthome released it?
This looks like the virtual com port (VCP) drivers have failed. I've seen this happen with other types of applications that rely on the FTDI VCP drivers.
Is shutting down and rebooting the HS machine the only way to recover from this?
I only have three serial ports on my HS box so I chose the USB version over the serial. Should I have purchased the serial PLM to avoid this problem or does it suffer from lock-ups as well?
Here's my log...
