Reset Zee and re-load Z-Wave network
    Zee is working pretty good using new release (3.00.42)
    Couple of things I figured out how to reset ZEE or just turn H3 off
    How do I reset the Z-Wave network. I am using the ZEE as a secondary controller and my Intermatic thermostats are not working completely I suspect that they need to be re-imported or something. The log is full of messages like Z-Wave Multilevel Sensor device Main Dinning Downstairs Temperature is missing Sensor Type information - cannot update sensor status.
    Any suggestions ? maybe delete devices and re-send data from primary how do I do this ?
    You can shutdown HS3 from the Tools -> System menu.
    I've not tried to completely reset the ZWave network. Try deleting the controller itself and re-adding it.
    HS4Pro on a Raspberry Pi4
    HSTouch Clients: 1 Android
      HS2 vs HS3 Z-Wave
      Here are some screen shots of the two systems (PC running HS2 and ZEE running HS3)
        I would try a rescan on all of those devices before wiping and starting over.
        Most of the devices in there just need a rescan to get the node info.
        Try one node first - click on the node itself, then the ZWave tab, then click rescan.
        The device would need to be in some reasonable range to the Zee.
          Re-scan of thermostats
          Ok that seemed to help just doing a re-scan on the thermostats then restart the ZEE and log comes up clean.
          Thanks for the help will keep trying this stuff out
