The Insteon Plugin Groups are working great, but the location portion of the "Group Name" changes unexpectedly. Can you take a look at the plugin group questions below?
-When creating a group I wish to leave "Group Location" empty, but the plugin keeps generating a value for location. For Alexa I do not want the group to be called "[Location] Shutdown house" (See image). The work around is to manually set "Room" to blank in the HS3 main view. Note the room keeps re-appearing when I mess with the groups (i.e. Add/Edit group).
-When I try giving a custom "Group Location" (i.e. House) it eventually ends up returning to the name "Group 1 Location" (See image).
-Also the plugin groups are a little more like scenes as all the devices in the group have a fixed programmed setting (i.e. OFF or ON). Does groups or alternative provide a way to say put 2 lamps together in a group (i.e. reading lamps). Then say "reading lamps" on or off to turn the group on or off?
HS3 Pro Edition 3.0.0.368
Insteon plugin v3.0.6.0.32
