No not HS touch. I'm referring to events in HS3. My bad. I will post screen shots soon.
HSTouch Play/Pause Toggle Button
Originally posted by w0012979 View PostNo not HS touch. I'm referring to events in HS3. My bad. I will post screen shots soon.
It all smells like a corruption between your HS database and the Sonos.ini config file.
Dirk
Originally posted by w0012979 View PostNo errors in the start-up log. I don't have a Playbar.
On a side note, the new S1 as you can see in the table is called now S12, the version of the PI you are using does not support the S12 BUT I don't think this is your problem nor do I think in absence of a Playbar that you should upgrade. Maybe, something went wrong when the S1 was originally added to HS. If we can't see a reason why they are not there, you could hit that delete button ONLY for that player, the PI will rediscover the player and re-add the player. When you do that, I would particularly monitor the log file for errors, just in case the issues is somewhere else (ex someone recently exceeded the max # of HS devices (9999) that could be created/deleted/re-created. If you do delete that single player and the existing HS devices for it don't get deleted, it would mean that HS DB and Sonos.INI file are out of sync, most likely due to some previous manual delete action or DB restoration action or ???
Dirk
The device page looked okay.
I deleted the player and the devices deleted with it. I re-added the player and the "state device" and other options appeared. There were errors in the log when it was re-added but I'm not sure if they have any effect.
Jan-25 11:34:15 PM
Warning
Unable to load device selectors(2).
Jan-25 11:34:15 PM
Error
DeSerializing object (byte): Unable to load type A.cb99c99729402f641d5b80229dc8a0905+clsSelectorData required for deserialization. Source=mscorlib
Jan-25 11:31:30 PM
Sonos
CreateSonosControllers: Created instance of ZonePlayerController for Zoneplayer = Bathroom with index 4
Jan-25 11:31:27 PM
Warning
Plugin Sonos is not responding but it is still running, not restarting yet.
Jan-25 11:31:26 PM
Error
Posting back to plugin web page SonosConfig: Object reference not set to an instance of an object.-> at System.Runtime.Remoting.Messaging.LogicalCallContext.Propaga teIncomingHeadersToCallContext(IMessage msg) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(Mess ageData& msgData, Int32 type) at HomeSeerAPI.IPlugInAPI.PostBackProc(String page, String data, String user, Int32 userRights) at Scheduler.proxyPage.postBackProc(StateObject& state, String Data)
Jan-25 11:31:24 PM
Sonos
DirectConnect called for Zone Bathroom with device name = uuid:RINCON_949F3E0B049401400 and Model = S12
Jan-25 11:31:18 PM
Warning
Webserver accept callback: An existing connection was forcibly closed by the remote host
Jan-25 11:31:13 PM
HSTouch Server Warning
Exception on Value Change callback: Object reference not set to an instance of an object.
Jan-25 11:31:12 PM
Jan-25 11:31:07 PM
Sonos
InitIO Called for Instance = RINCON_949F3E0B049401400 and running on OS = Win32NT
Jan-25 11:31:07 PM
Info
Plugin Sonos with instance RINCON_949F3E0B049401400 has connected. IP:127.0.0.1:1786
Jan-25 11:31:07 PM
Sonos
CreatePlayerDevice: Created device Player with reference 309 and ZoneModel = S12
Jan-25 11:30:45 PM
Device Control
Device: Sonos Rec Room Volume to Volume (value)% (43) by/from: CAPI Control Handler
Jan-25 11:29:20 PM
Sonos
DeleteDevice deleted HS Device Ref = 302
Jan-25 11:29:20 PM
Sonos
DeleteDevice deleted HS Device Ref = 301
Jan-25 11:29:20 PM
Sonos
DeleteDevice deleted HS Device Ref = 300
Jan-25 11:29:19 PM
Sonos
DeleteDevice deleted HS Device Ref = 299
Jan-25 11:29:19 PM
Sonos
DeleteDevice deleted HS Device Ref = 298
Jan-25 11:29:19 PM
Sonos
DeleteDevice deleted HS Device Ref = 297
Jan-25 11:29:19 PM
Sonos
DeleteDevice deleted HS Device Ref = 296
Jan-25 11:29:19 PM
Sonos
DeleteDevice deleted HS Device Ref = 295
Jan-25 11:29:19 PM
Sonos
DeleteDevice deleted HS Device Ref = 294
Jan-25 11:29:19 PM
Sonos
DeleteDevice deleted HS Device Ref = 293
Jan-25 11:29:19 PM
Sonos
DeleteDevice deleted HS Device Ref = 292
Jan-25 11:29:19 PM
Sonos
DeleteDevice deleted HS Device Ref = 291
Jan-25 11:29:19 PM
Sonos
DeleteDevice deleted HS Device Ref = 290
Jan-25 11:29:19 PM
Sonos
DeleteDevice deleted HS Device Ref = 289
Jan-25 11:29:19 PM
Sonos
DeleteDevice deleted HS Device Ref = 288
Jan-25 11:29:19 PM
Sonos
DeleteDevice deleted HS Device Ref = 287
Jan-25 11:29:19 PM
Sonos
DeleteDevice deleted HS Device Ref = 286
Jan-25 11:29:19 PM
Sonos
DeleteDevice deleted HS Device Ref = 285
Jan-25 11:29:19 PM
Sonos
DeleteDevice deleted HS Device Ref = 281
Jan-25 11:29:19 PM
Info
Plugin Sonos with instance: RINCON_949F3E0B049401400 has disconnected
Jan-25 11:29:19 PM
Sonos
DeleteDevice called with DeviceUDN = RINCON_949F3E0B049401400
Jan-25 11:29:19 PM
Sonos
Disconnect: Disconnected from ZonePlayer - Bathroom
Jan-25 11:29:19 PM
Sonos
ShutdownIO called for Instance = RINCON_949F3E0B049401400 and isRoot = False
Jan-25 11:28:47 PM
Sonos
ConfigDevice called for instance = and zoneplayer = with Ref = 37 and user = default and userRights = 6 and newDevice = False
