I am using HS on linux at a remote property to manage a Schlage lock, automate an outdoor light and monitor temp/humidity. I have a always on internet connection there.
I figured I could probably remote load the Z-Wave plugin and have it connect to my main HS system instead of running two HS box.
On my linux HS I run:
I get the following on my Windows server:
Is there a way to make this work or do I absolutly need a Windows HS box to remote load to another HS box?
Could the windows HSPI_ZWave.exe be run with mono?
I find it a bit intense to run a full Windows computer only to run the Z-Wave plugin.
Math
mono HSPI_ZWave.exe server=xxx.xxx.xxx.xxx Connecting to server at xxx.xxx.xxx.xxx... Connected, waiting to be initialized...
August-25 14:08:38 Info Plugin Z-Wave with instance: has disconnected August-25 14:08:35 Z-Wave Database: Opening (Mode=Read Only) up HomeSeer database /root/HomeSeer/Data/Z-Wave/Z-Wave.db August-25 14:08:34 Error Initializing plug-in(1): Z-Wave Instance::Error, wrong OS type August-25 14:08:34 Z-Wave This plug-in is formatted for Linux and will not run on this OS, exiting August-25 14:08:34 Z-Wave InitIO called, plug-in version 3.0.0.168 is being initialized... August-25 14:08:34 Info Plugin Z-Wave has connected. IP:xxx.xxx.xxx.xxx:48424
Math
