I've spent the last 4 hours trying to solve this to no avail. Let me explain what I'm trying to do in case there is a different way to do it.
I am trying to remotely debug an issue with a battery operated Z-Wave device, which I believe to be a configuration issue (addressable through Z-Wave configuration). Ideally I want to know what the current settings are so that I can confirm my suspicions, but a backup plan is just to set the configuration the way that I want and then monitor to see that the issue is resolved.
The problems that I'm running into are the following:
1) I can't get the configuration values programmatically as the device is not listening (and therefore fails) and I can't figure out how to queue the Configuration_Get command in the Z-Wave plugin.
2) I can't set the configuration value through the device's Z-Wave information since it isn't listening and therefore I can't set a configuration parameter to be queued for when the device wakes up. (I suspect I also could not set it through a script for the same reason of not being able to be queued).
3) There seems to be no way to create an event that is triggered on a device waking up to be able to script interaction with the device while it is awake (to get or set the configuration).
Any thoughts on how to get (or set) the config while the device is not listening and have it queue? Or, alternately, how to create an event on when the device wakes up to get/set the config?
Chris
PS. In case anyone wants more information, I'm using a Zipato (Philio) Multisensor Quad that was used in a previously deployment. It will keep certain configuration values between networks and is behaving strangely, so I want to verify a particular setting prior to sending what I believe is the correct configuration.
Chris
