Okay! I'm having issues with a 3-way where the load and the line are coming into different boxes with a 3-wire in between. Image 1 below shows the configuration. Image 2 is a sketch of how I tried to wire it. I used the black of the 3-wire to carry the line/hot over to the box with the load. I want the HS Dimmer in the box with the load and the companion switch in the box with the line. Any guidance would be much appreciated. I'm sure its something very simple and I'm just not seeing it. Thanks
3-way help: load in one box, line in the other
Your wiring diagram looks right, it should have worked. I just did the same thing a couple of weeks ago and it did not work first try. I was perplexed. Turned out one of my neutral wires broke off inside one of the wire nuts. I did it just like your hand drawn diagram carrying the hot over the 3-conductor on the black wire. Try rechecking all your connections.
It appears you don't have any current going to the companion switch. The companion switch (if it is like the one I am screwing around with, now) is nothing more than a radio, but it needs a hot and neutral. The traveler is used only to carry current into the non-line box. You really only need three wires (not counting the ground) for the master box.
The directions provided by Cooper really suck and (in my experience) are nothing like houses are actually wired... colors or actual wiring....HomeSeer Version: HS4 Pro Edition 4.2.19.0 (Windows - Running as a Service)
Home Assistant 2024.3
Enabled Plug-Ins
Originally posted by jhearty View PostI presume he has a HomeSeer switch based on the forum posted. That being the case the accessory switch only has neutral and traveler, no hot.HomeSeer Version: HS4 Pro Edition 4.2.19.0 (Windows - Running as a Service)
Enabled Plug-Ins
Originally posted by cheeryfool View PostAgreed. The hand drawn diagram looks correct to me. The blacks should be wire nutted together at the accessory switch. The only wire connecting the switches is the red traveler that carries a low voltage signal - oh and the neutral.
Not to hijack, but out of curiosity.... does the traveler actually send a signal or does it just power a transmitter? Looks like I need to do some relearning, since I'm in the process of using up my last "old style" pair....HomeSeer Version: HS4 Pro Edition 4.2.19.0 (Windows - Running as a Service)
Enabled Plug-Ins
Originally posted by ewkearns View PostNot to hijack, but out of curiosity.... does the traveler actually send a signal or does it just power a transmitter? Looks like I need to do some relearning, since I'm in the process of using up my last "old style" pair....HS4 Pro, 4.2.19.0 Windows 10 pro, Supermicro LP Xeon
Thanks!HomeSeer Version: HS4 Pro Edition 4.2.19.0 (Windows - Running as a Service)
Enabled Plug-Ins
man oh man.. i searched the site the other day and didnt see this. so did my own thread...
yeah i ran into the same problem.. the easy way to explain how i did it was..
use a traveler wire (black) go take power from 1 box to the other...HW - i5 4570T @2.9ghz runs @11w | 8gb ram | 128gb ssd OS - Win10 x64
