I have installed the modbus plugin and all seemed to work for a short while then i noticed that device values where not being updated. If i disable and then re enable the plugin it works for a short while again. i have also tried deleting devices and gateway and starting fresh but with same results. Any ideas?
Connected to Click PLC
Thanks in advance
Nick
Current Date/Time: 29/12/2016 20:16:31
HomeSeer Version: HS3 Pro Edition 3.0.0.298
Operating System: Microsoft Windows 7 Professional - Work Station
System Uptime: 0 Days 2 Hours 54 Minutes 17 Seconds
IP Address: 192.168.0.6
Number of Devices: 176
Number of Events: 8
Available Threads: 400
Enabled Plug-Ins
3.0.0.104: HSTouch Server
3.8.6121.22741: Modbus
3.0.0.21: Nest
3.1.0.18: Sonos
3.0.0.36: X10
Dec-29 20:19:36 Modbus Error Read error for Click Output 6
Dec-29 20:19:36 Modbus Error Error in Read: Response was not of expected transaction ID. Expected 4728, received 4727.
Dec-29 20:19:36 Modbus Debug Reading Slave: 2 Address: 8198 Coil:Bool
Dec-29 20:19:36 Modbus Error Read error for Click Compressor
Dec-29 20:19:35 Modbus Error Error in Read: Response was not of expected transaction ID. Expected 4723, received 4722.
Dec-29 20:19:35 Modbus Debug Reading Slave: 2 Address: 16404 Coil:Bool
Dec-29 20:19:35 Modbus Error Read error for Analog In 2
Dec-29 20:19:35 Modbus Error Error in Read: Response was not of expected transaction ID. Expected 4718, received 4717.
Dec-29 20:19:35 Modbus Error Error in ReadFloat32: Response was not of expected transaction ID. Expected 4718, received 4717.
Dec-29 20:19:35 Modbus Debug Reading Slave: 2 Address: 28676 HoldingRegister:Float32
Dec-29 20:19:35 Modbus Error Read error for Analog In 1 Amps
Dec-29 20:19:35 Modbus Error Error in Read: Response was not of expected transaction ID. Expected 4713, received 4712.
Dec-29 20:19:35 Modbus Error Error in ReadFloat32: Response was not of expected transaction ID. Expected 4713, received 4712.
Dec-29 20:19:35 Modbus Debug Reading Slave: 2 Address: 28674 HoldingRegister:Float32
Dec-29 20:19:35 Modbus Error Read error for Click X1
Dec-29 20:19:35 Modbus Error Error in Read: Response was not of expected transaction ID. Expected 4708, received 4707.
Dec-29 20:19:35 Modbus Debug Reading Slave: 2 Address: 1 DiscreteInput:Bool
Dec-29 20:19:35 Modbus Error Read error for Compressor Run time Countdown
Dec-29 20:19:35 Modbus Error Error in Read: Response was not of expected transaction ID. Expected 4703, received 4702.
Dec-29 20:19:35 Modbus Debug Reading Slave: 2 Address: 51 HoldingRegister:Int16
Dec-29 20:19:35 Modbus Error Read error for Compressor Run Time PRE
Dec-29 20:19:35 Modbus Error Error in Read: Response was not of expected transaction ID. Expected 4698, received 4697.
Dec-29 20:19:35 Modbus Debug Reading Slave: 2 Address: 1 HoldingRegister:Int16
Dec-29 20:19:35 Modbus Debug Polling Modbus IP Gateway Click PLC. Reading 7 registers from slaves
Dec-29 20:19:26 Modbus Error Read error for Click Output 6
Dec-29 20:19:26 Modbus Error Error in Read: Response was not of expected transaction ID. Expected 4693, received 4692.
Dec-29 20:19:26 Modbus Debug Reading Slave: 2 Address: 8198 Coil:Bool
Dec-29 20:19:25 Modbus Error Read error for Click Compressor
Dec-29 20:19:25 Modbus Error Error in Read: Response was not of expected transaction ID. Expected 4688, received 4687.
Dec-29 20:19:25 Modbus Debug Reading Slave: 2 Address: 16404 Coil:Bool
Dec-29 20:19:25 Modbus Error Read error for Analog In 2
Dec-29 20:19:25 Modbus Error Error in Read: Response was not of expected transaction ID. Expected 4683, received 4682.
Dec-29 20:19:25 Modbus Error Error in ReadFloat32: Response was not of expected transaction ID. Expected 4683, received 4682.
Dec-29 20:19:25 Modbus Debug Reading Slave: 2 Address: 28676 HoldingRegister:Float32
Dec-29 20:19:25 Modbus Error Read error for Analog In 1 Amps
Dec-29 20:19:25 Modbus Error Error in Read: Response was not of expected transaction ID. Expected 4678, received 4677.
Dec-29 20:19:25 Modbus Error Error in ReadFloat32: Response was not of expected transaction ID. Expected 4678, received 4677.
Dec-29 20:19:25 Modbus Debug Reading Slave: 2 Address: 28674 HoldingRegister:Float32
Dec-29 20:19:25 Modbus Error Read error for Click X1
Dec-29 20:19:25 Modbus Error Error in Read: Response was not of expected transaction ID. Expected 4673, received 4672.
Dec-29 20:19:25 Modbus Debug Reading Slave: 2 Address: 1 DiscreteInput:Bool
Dec-29 20:19:25 Modbus Error Read error for Compressor Run time Countdown
Dec-29 20:19:25 Modbus Error Error in Read: Response was not of expected transaction ID. Expected 4668, received 4667.
Dec-29 20:19:25 Modbus Debug Reading Slave: 2 Address: 51 HoldingRegister:Int16
Dec-29 20:19:25 Modbus Error Read error for Compressor Run Time PRE
Dec-29 20:19:25 Modbus Error Error in Read: Response was not of expected transaction ID. Expected 4663, received 4662.
Dec-29 20:19:25 Modbus Debug Reading Slave: 2 Address: 1 HoldingRegister:Int16
Dec-29 20:19:25 Modbus Debug Polling Modbus IP Gateway Click PLC. Reading 7 registers from slaves
Dec-29 20:19:16 Modbus Error Read error for Click Output 6
Dec-29 20:19:16 Modbus Error Error in Read: Response was not of expected transaction ID. Expected 4658, received 4657.
Dec-29 20:19:16 Modbus Debug Reading Slave: 2 Address: 8198 Coil:Bool
Dec-29 20:19:16 Modbus Error Read error for Click Compressor
Dec-29 20:19:16 Modbus Error Error in Read: Response was not of expected transaction ID. Expected 4653, received 4652.
Dec-29 20:19:16 Modbus Debug Reading Slave: 2 Address: 16404 Coil:Bool
Dec-29 20:19:15 Modbus Error Read error for Analog In 2
Dec-29 20:19:15 Modbus Error Error in Read: Response was not of expected transaction ID. Expected 4648, received 4647.
Dec-29 20:19:15 Modbus Error Error in ReadFloat32: Response was not of expected transaction ID. Expected 4648, received 4647.
Dec-29 20:19:15 Modbus Debug Reading Slave: 2 Address: 28676 HoldingRegister:Float32
Dec-29 20:19:15 Modbus Error Read error for Analog In 1 Amps
Dec-29 20:19:15 Modbus Error Error in Read: Response was not of expected transaction ID. Expected 4643, received 4642.
Dec-29 20:19:15 Modbus Error Error in ReadFloat32: Response was not of expected transaction ID. Expected 4643, received 4642.
Dec-29 20:19:15 Modbus Debug Reading Slave: 2 Address: 28674 HoldingRegister:Float32
Dec-29 20:19:15 Modbus Error Read error for Click X1
Dec-29 20:19:15 Modbus Error Error in Read: Response was not of expected transaction ID. Expected 4638, received 4637.
Dec-29 20:19:15 Modbus Debug Reading Slave: 2 Address: 1 DiscreteInput:Bool
Dec-29 20:19:15 Modbus Error Read error for Compressor Run time Countdown
Dec-29 20:19:15 Modbus Error Error in Read: Response was not of expected transaction ID. Expected 4633, received 4632.
Dec-29 20:19:15 Modbus Debug Reading Slave: 2 Address: 51 HoldingRegister:Int16
Dec-29 20:19:15 Modbus Error Read error for Compressor Run Time PRE
Dec-29 20:19:15 Modbus Error Error in Read: Response was not of expected transaction ID. Expected 4628, received 4627.
Dec-29 20:19:15 Modbus Debug Reading Slave: 2 Address: 1 HoldingRegister:Int16
Dec-29 20:19:15 Modbus Debug Polling Modbus IP Gateway Click PLC. Reading 7 registers from slaves
Dec-29 20:19:14 Event Event Trigger "Heating Room Temp Copy To Modbus"
Dec-29 20:19:06 Modbus Error Read error for Click Output 6
Dec-29 20:19:06 Modbus Error Error in Read: Response was not of expected transaction ID. Expected 4623, received 4622.
Dec-29 20:19:06 Modbus Debug Reading Slave: 2 Address: 8198 Coil:Bool
Dec-29 20:19:06 Modbus Error Read error for Click Compressor
Dec-29 20:19:06 Modbus Error Error in Read: Response was not of expected transaction ID. Expected 4618, received 4617.
Dec-29 20:19:05 Modbus Debug Reading Slave: 2 Address: 16404 Coil:Bool
Dec-29 20:19:05 Modbus Error Read error for Analog In 2
Dec-29 20:19:05 Modbus Error Error in Read: Response was not of expected transaction ID. Expected 4613, received 4612.
Dec-29 20:19:05 Modbus Error Error in ReadFloat32: Response was not of expected transaction ID. Expected 4613, received 4612.
Dec-29 20:19:05 Modbus Debug Reading Slave: 2 Address: 28676 HoldingRegister:Float32
Dec-29 20:19:05 Modbus Error Read error for Analog In 1 Amps
Dec-29 20:19:05 Modbus Error Error in Read: Response was not of expected transaction ID. Expected 4608, received 4607.
Dec-29 20:19:05 Modbus Error Error in ReadFloat32: Response was not of expected transaction ID. Expected 4608, received 4607.
Dec-29 20:19:05 Modbus Debug Reading Slave: 2 Address: 28674 HoldingRegister:Float32
Dec-29 20:19:05 Modbus Error Read error for Click X1
Dec-29 20:19:05 Modbus Error Error in Read: Response was not of expected transaction ID. Expected 4603, received 4602.
Dec-29 20:19:05 Modbus Debug Reading Slave: 2 Address: 1 DiscreteInput:Bool
Dec-29 20:19:05 Modbus Error Read error for Compressor Run time Countdown
Dec-29 20:19:05 Modbus Error Error in Read: Response was not of expected transaction ID. Expected 4598, received 4597.
Dec-29 20:19:05 Modbus Debug Reading Slave: 2 Address: 51 HoldingRegister:Int16
Dec-29 20:19:05 Modbus Error Read error for Compressor Run Time PRE
Dec-29 20:19:05 Modbus Error Error in Read: Response was not of expected transaction ID. Expected 4593, received 4592.
Dec-29 20:19:05 Modbus Debug Reading Slave: 2 Address: 1 HoldingRegister:Int16
Dec-29 20:19:05 Modbus Debug Polling Modbus IP Gateway Click PLC. Reading 7 registers from slaves
Dec-29 20:18:56 Modbus Error Read error for Click Output 6
Dec-29 20:18:56 Modbus Error Error in Read: Response was not of expected transaction ID. Expected 4588, received 4587.
Dec-29 20:18:56 Modbus Debug Reading Slave: 2 Address: 8198 Coil:Bool
Dec-29 20:18:56 Modbus Error Read error for Click Compressor
Dec-29 20:18:56 Modbus Error Error in Read: Response was not of expected transaction ID. Expected 4583, received 4582.
Dec-29 20:18:55 Modbus Debug Reading Slave: 2 Address: 16404 Coil:Bool
Dec-29 20:18:55 Modbus Error Read error for Analog In 2
Dec-29 20:18:55 Modbus Error Error in Read: Response was not of expected transaction ID. Expected 4578, received 4577.
Dec-29 20:18:55 Modbus Error Error in ReadFloat32: Response was not of expected transaction ID. Expected 4578, received 4577.
Dec-29 20:18:55 Modbus Debug Reading Slave: 2 Address: 28676 HoldingRegister:Float32
Dec-29 20:18:55 Modbus Error Read error for Analog In 1 Amps
Dec-29 20:18:55 Modbus Error Error in Read: Response was not of expected transaction ID. Expected 4573, received 4572.
Dec-29 20:18:55 Modbus Error Error in ReadFloat32: Response was not of expected transaction ID. Expected 4573, received 4572.
Dec-29 20:18:55 Modbus Debug Reading Slave: 2 Address: 28674 HoldingRegister:Float32
Dec-29 20:18:55 Modbus Error Read error for Click X1
Dec-29 20:18:55 Modbus Error Error in Read: Response was not of expected transaction ID. Expected 4568, received 4567.
Dec-29 20:18:55 Modbus Debug Reading Slave: 2 Address: 1 DiscreteInput:Bool
Dec-29 20:18:55 Modbus Error Read error for Compressor Run time Countdown
Dec-29 20:18:55 Modbus Error Error in Read: Response was not of expected transaction ID. Expected 4563, received 4562.
Dec-29 20:18:55 Modbus Debug Reading Slave: 2 Address: 51 HoldingRegister:Int16
Dec-29 20:18:55 Modbus Error Read error for Compressor Run Time PRE
Dec-29 20:18:55 Modbus Error Error in Read: Response was not of expected transaction ID. Expected 4558, received 4557.
Dec-29 20:18:55 Modbus Debug Reading Slave: 2 Address: 1 HoldingRegister:Int16
Dec-29 20:18:55 Modbus Debug Polling Modbus IP Gateway Click PLC. Reading 7 registers from slaves
Dec-29 20:18:45 Modbus Error Read error for Click Output 6
Dec-29 20:18:45 Modbus Error Error in Read: Response was not of expected transaction ID. Expected 4553, received 4552.
Dec-29 20:18:45 Modbus Debug Reading Slave: 2 Address: 8198 Coil:Bool
Dec-29 20:18:45 Modbus Error Read error for Click Compressor
Dec-29 20:18:45 Modbus Error Error in Read: Response was not of expected transaction ID. Expected 4548, received 4547.
Dec-29 20:18:45 Modbus Debug Reading Slave: 2 Address: 16404 Coil:Bool
Dec-29 20:18:45 Modbus Error Read error for Analog In 2
Dec-29 20:18:45 Modbus Error Error in Read: Response was not of expected transaction ID. Expected 4543, received 4542.
Dec-29 20:18:45 Modbus Error Error in ReadFloat32: Response was not of expected transaction ID. Expected 4543, received 4542.
Dec-29 20:18:45 Modbus Debug Reading Slave: 2 Address: 28676 HoldingRegister:Float32
Dec-29 20:18:45 Modbus Error Read error for Analog In 1 Amps
Dec-29 20:18:45 Modbus Error Error in Read: Response was not of expected transaction ID. Expected 4538, received 4537.
Dec-29 20:18:45 Modbus Error Error in ReadFloat32: Response was not of expected transaction ID. Expected 4538, received 4537.
Dec-29 20:18:45 Modbus Debug Reading Slave: 2 Address: 28674 HoldingRegister:Float32
Dec-29 20:18:45 Modbus Error Read error for Click X1
Dec-29 20:18:45 Modbus Error Error in Read: Response was not of expected transaction ID. Expected 4533, received 4532.
Dec-29 20:18:45 Modbus Debug Reading Slave: 2 Address: 1 DiscreteInput:Bool
Dec-29 20:18:45 Modbus Error Read error for Compressor Run time Countdown
Dec-29 20:18:45 Modbus Error Error in Read: Response was not of expected transaction ID. Expected 4528, received 4527.
Dec-29 20:18:45 Modbus Debug Reading Slave: 2 Address: 51 HoldingRegister:Int16
Dec-29 20:18:45 Modbus Error Read error for Compressor Run Time PRE
Dec-29 20:18:45 Modbus Error Error in Read: Response was not of expected transaction ID. Expected 4523, received 4522.
Dec-29 20:18:45 Modbus Debug Reading Slave: 2 Address: 1 HoldingRegister:Int16
Dec-29 20:18:45 Modbus Debug Polling Modbus IP Gateway Click PLC. Reading 7 registers from slaves
Dec-29 20:18:35 Modbus Error Read error for Click Output 6
Dec-29 20:18:35 Modbus Error Error in Read: Response was not of expected transaction ID. Expected 4518, received 4517.
Dec-29 20:18:35 Modbus Debug Reading Slave: 2 Address: 8198 Coil:Bool
Dec-29 20:18:35 Modbus Error Read error for Click Compressor
Dec-29 20:18:35 Modbus Error Error in Read: Response was not of expected transaction ID. Expected 4513, received 4512.
Dec-29 20:18:35 Modbus Debug Reading Slave: 2 Address: 16404 Coil:Bool
Dec-29 20:18:35 Modbus Error Read error for Analog In 2
Dec-29 20:18:35 Modbus Error Error in Read: Response was not of expected transaction ID. Expected 4508, received 4507.
Dec-29 20:18:35 Modbus Error Error in ReadFloat32: Response was not of expected transaction ID. Expected 4508, received 4507.
Dec-29 20:18:35 Modbus Debug Reading Slave: 2 Address: 28676 HoldingRegister:Float32
Dec-29 20:18:35 Modbus Error Read error for Analog In 1 Amps
Dec-29 20:18:35 Modbus Error Error in Read: Response was not of expected transaction ID. Expected 4503, received 4502.
Dec-29 20:18:35 Modbus Error Error in ReadFloat32: Response was not of expected transaction ID. Expected 4503, received 4502.
Dec-29 20:18:35 Modbus Debug Reading Slave: 2 Address: 28674 HoldingRegister:Float32
Dec-29 20:18:35 Modbus Error Read error for Click X1
Dec-29 20:18:35 Modbus Error Error in Read: Response was not of expected transaction ID. Expected 4498, received 4497.
Dec-29 20:18:35 Modbus Debug Reading Slave: 2 Address: 1 DiscreteInput:Bool
Dec-29 20:18:35 Modbus Error Read error for Compressor Run time Countdown
Dec-29 20:18:35 Modbus Error Error in Read: Response was not of expected transaction ID. Expected 4493, received 4492.
Dec-29 20:18:35 Modbus Debug Reading Slave: 2 Address: 51 HoldingRegister:Int16
Dec-29 20:18:35 Modbus Error Read error for Compressor Run Time PRE
Dec-29 20:18:35 Modbus Error Error in Read: Response was not of expected transaction ID. Expected 4488, received 4487.
Dec-29 20:18:35 Modbus Debug Reading Slave: 2 Address: 1 HoldingRegister:Int16
Dec-29 20:18:35 Modbus Debug Polling Modbus IP Gateway Click PLC. Reading 7 registers from slaves
Dec-29 20:18:26 Modbus Error Read error for Click Output 6
Dec-29 20:18:26 Modbus Error Error in Read: Response was not of expected transaction ID. Expected 4483, received 4482.
Dec-29 20:18:26 Modbus Debug Reading Slave: 2 Address: 8198 Coil:Bool
Dec-29 20:18:25 Modbus Error Read error for Click Compressor
Dec-29 20:18:25 Modbus Error Error in Read: Response was not of expected transaction ID. Expected 4478, received 4477.
Dec-29 20:18:25 Modbus Debug Reading Slave: 2 Address: 16404 Coil:Bool
Dec-29 20:18:25 Modbus Error Read error for Analog In 2
Dec-29 20:18:25 Modbus Error Error in Read: Response was not of expected transaction ID. Expected 4473, received 4472.
Dec-29 20:18:25 Modbus Error Error in ReadFloat32: Response was not of expected transaction ID. Expected 4473, received 4472.
Dec-29 20:18:25 Modbus Debug Reading Slave: 2 Address: 28676 HoldingRegister:Float32
Dec-29 20:18:25 Modbus Error Read error for Analog In 1 Amps
Dec-29 20:18:25 Modbus Error Error in Read: Response was not of expected transaction ID. Expected 4468, received 4467.
Dec-29 20:18:25 Modbus Error Error in ReadFloat32: Response was not of expected transaction ID. Expected 4468, received 4467.
Dec-29 20:18:25 Modbus Debug Reading Slave: 2 Address: 28674 HoldingRegister:Float32
Dec-29 20:18:25 Modbus Error Read error for Click X1
Dec-29 20:18:25 Modbus Error Error in Read: Response was not of expected transaction ID. Expected 4463, received 4462.
Dec-29 20:18:25 Modbus Debug Reading Slave: 2 Address: 1 DiscreteInput:Bool
Dec-29 20:18:25 Modbus Error Read error for Compressor Run time Countdown
Dec-29 20:18:25 Modbus Error Error in Read: Response was not of expected transaction ID. Expected 4458, received 4457.
Dec-29 20:18:25 Modbus Debug Reading Slave: 2 Address: 51 HoldingRegister:Int16
Dec-29 20:18:25 Modbus Error Read error for Compressor Run Time PRE
Dec-29 20:18:25 Modbus Error Error in Read: Response was not of expected transaction ID. Expected 4453, received 4452.
Dec-29 20:18:25 Modbus Debug Reading Slave: 2 Address: 1 HoldingRegister:Int16
Dec-29 20:18:25 Modbus Debug Polling Modbus IP Gateway Click PLC. Reading 7 registers from slaves
Dec-29 20:18:15 Modbus Error Read error for Click Output 6
Dec-29 20:18:15 Modbus Error Error in Read: Response was not of expected transaction ID. Expected 4448, received 4447.
Dec-29 20:18:15 Modbus Debug Reading Slave: 2 Address: 8198 Coil:Bool
Dec-29 20:18:15 Modbus Error Read error for Click Compressor
Dec-29 20:18:15 Modbus Error Error in Read: Response was not of expected transaction ID. Expected 4443, received 4442.
Dec-29 20:18:15 Modbus Debug Reading Slave: 2 Address: 16404 Coil:Bool
Dec-29 20:18:15 Modbus Error Read error for Analog In 2
Dec-29 20:18:15 Modbus Error Error in Read: Response was not of expected transaction ID. Expected 4438, received 4437.
Dec-29 20:18:15 Modbus Error Error in ReadFloat32: Response was not of expected transaction ID. Expected 4438, received 4437.
Dec-29 20:18:15 Modbus Debug Reading Slave: 2 Address: 28676 HoldingRegister:Float32
Dec-29 20:18:15 Modbus Error Read error for Analog In 1 Amps
Dec-29 20:18:15 Modbus Error Error in Read: Response was not of expected transaction ID. Expected 4433, received 4432.
Dec-29 20:18:15 Modbus Error Error in ReadFloat32: Response was not of expected transaction ID. Expected 4433, received 4432.
Dec-29 20:18:15 Modbus Debug Reading Slave: 2 Address: 28674 HoldingRegister:Float32
Dec-29 20:18:15 Modbus Error Read error for Click X1
Dec-29 20:18:15 Modbus Error Error in Read: Response was not of expected transaction ID. Expected 4428, received 4427.
Dec-29 20:18:15 Modbus Debug Reading Slave: 2 Address: 1 DiscreteInput:Bool
Dec-29 20:18:15 Modbus Error Read error for Compressor Run time Countdown
Dec-29 20:18:15 Modbus Error Error in Read: Response was not of expected transaction ID. Expected 4423, received 4422.
Dec-29 20:18:15 Modbus Debug Reading Slave: 2 Address: 51 HoldingRegister:Int16
Dec-29 20:18:15 Modbus Error Read error for Compressor Run Time PRE
Dec-29 20:18:15 Modbus Error Error in Read: Response was not of expected transaction ID. Expected 4418, received 4417.
Dec-29 20:18:15 Modbus Debug Reading Slave: 2 Address: 1 HoldingRegister:Int16
Dec-29 20:18:15 Modbus Debug Polling Modbus IP Gateway Click PLC. Reading 7 registers from slaves
Dec-29 20:18:05 Modbus Error Read error for Click Output 6
Dec-29 20:18:05 Modbus Error Error in Read: Response was not of expected transaction ID. Expected 4413, received 4412.
Dec-29 20:18:05 Modbus Debug Reading Slave: 2 Address: 8198 Coil:Bool
Dec-29 20:18:05 Modbus Error Read error for Click Compressor
Dec-29 20:18:05 Modbus Error Error in Read: Response was not of expected transaction ID. Expected 4408, received 4407.
Dec-29 20:18:05 Modbus Debug Reading Slave: 2 Address: 16404 Coil:Bool
Dec-29 20:18:05 Modbus Error Read error for Analog In 2
Dec-29 20:18:05 Modbus Error Error in Read: Response was not of expected transaction ID. Expected 4403, received 4402.
Dec-29 20:18:05 Modbus Error Error in ReadFloat32: Response was not of expected transaction ID. Expected 4403, received 4402.
Dec-29 20:18:05 Modbus Debug Reading Slave: 2 Address: 28676 HoldingRegister:Float32
Dec-29 20:18:05 Modbus Error Read error for Analog In 1 Amps
Dec-29 20:18:05 Modbus Error Error in Read: Response was not of expected transaction ID. Expected 4398, received 4397.
Dec-29 20:18:05 Modbus Error Error in ReadFloat32: Response was not of expected transaction ID. Expected 4398, received 4397.
Dec-29 20:18:05 Modbus Debug Reading Slave: 2 Address: 28674 HoldingRegister:Float32
Dec-29 20:18:05 Modbus Error Read error for Click X1
Dec-29 20:18:05 Modbus Error Error in Read: Response was not of expected transaction ID. Expected 4393, received 4392.
Dec-29 20:18:05 Modbus Debug Reading Slave: 2 Address: 1 DiscreteInput:Bool
Dec-29 20:18:05 Modbus Error Read error for Compressor Run time Countdown
Dec-29 20:18:05 Modbus Error Error in Read: Response was not of expected transaction ID. Expected 4388, received 4387.
Dec-29 20:18:05 Modbus Debug Reading Slave: 2 Address: 51 HoldingRegister:Int16
Dec-29 20:18:05 Modbus Error Read error for Compressor Run Time PRE
Dec-29 20:18:05 Modbus Error Error in Read: Response was not of expected transaction ID. Expected 4383, received 4382.
Dec-29 20:18:05 Modbus Debug Reading Slave: 2 Address: 1 HoldingRegister:Int16
Dec-29 20:18:05 Modbus Debug Polling Modbus IP Gateway Click PLC. Reading 7 registers from slaves
Dec-29 20:17:55 Modbus Error Read error for Click Output 6
Dec-29 20:17:55 Modbus Error Error in Read: Response was not of expected transaction ID. Expected 4378, received 4377.
Dec-29 20:17:55 Modbus Debug Reading Slave: 2 Address: 8198 Coil:Bool
Dec-29 20:17:55 Modbus Error Read error for Click Compressor
Dec-29 20:17:55 Modbus Error Error in Read: Response was not of expected transaction ID. Expected 4373, received 4372.
Dec-29 20:17:55 Modbus Debug Reading Slave: 2 Address: 16404 Coil:Bool
Dec-29 20:17:55 Modbus Error Read error for Analog In 2
Dec-29 20:17:55 Modbus Error Error in Read: Response was not of expected transaction ID. Expected 4368, received 4367.
Dec-29 20:17:55 Modbus Error Error in ReadFloat32: Response was not of expected transaction ID. Expected 4368, received 4367.
Thanks in advance
Nick
Number of Events: 8
Enabled Plug-Ins
3.0.0.21: Nest
3.1.0.18: Sonos
3.0.0.36: X10
