Hi everyone. New homeseer user. Installed the edition included on the CD and started adding ZWave devices. I saw that the beta version would allow me to update nodes etc.. I updated homeseer to 2.1.151.0 and now it will not allow me to add plugins etc. Here is the message I get:
Server Error in '/' Application. <HR width="100%" color=silver SIZE=1>
Configuration Error
Description: An error occurred during the processing of a configuration file required to service this request. Please review the specific error details below and modify your configuration file appropriately.
Parser Error Message: Could not load file or assembly 'SKCLNET, Version=4.2.1.12, Culture=neutral, PublicKeyToken=d5770e63406d04a0' or one of its dependencies. The system cannot find the file specified.
Source Error:
<TABLE width="100%" bgColor=#ffffcc><TBODY><TR><TD><CODE>
Line 37: <add assembly="System.Runtime.Serialization.Formatters.Soap, Version=2.0.0.0, Culture=neutral, PublicKeyToken=B03F5F7F11D50A3A"/>Line 38: <add assembly="sysglobl, Version=2.0.0.0, Culture=neutral, PublicKeyToken=B03F5F7F11D50A3A"/>Line 39: <add assembly="SKCLNET, Version=4.2.1.12, Culture=neutral, PublicKeyToken=D5770E63406D04A0"/>Line 40: <add assembly="System.Configuration, Version=2.0.0.0, Culture=neutral, PublicKeyToken=B03F5F7F11D50A3A"/></assemblies></compilation>Line 41: <!--</PRE></CODE></TD></TR></TBODY></TABLE>
Source File: C:\Program Files\HomeSeer 2\html\updater\web.config Line: 39
Assembly Load Trace: The following information can be helpful to determine why the assembly 'SKCLNET, Version=4.2.1.12, Culture=neutral, PublicKeyToken=d5770e63406d04a0' could not be loaded.
WRN: Assembly binding logging is turned OFF.To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1.Note: There is some performance penalty associated with assembly bind failure logging.To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog].</PRE></CODE></TD></TR></TBODY></TABLE>
</P><HR width="100%" color=silver SIZE=1>Version Information: Microsoft .NET Framework Version:2.0.50727.42; ASP.NET Version:2.0.50727.210
Any ideas?<!-- [FileNotFoundException]: Could not load file or assembly 'SKCLNET, Version=4.2.1.12, Culture=neutral, PublicKeyToken=d5770e63406d04a0' or one of its dependencies. The system cannot find the file specified. at System.Reflection.Assembly.nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, Assembly locationHint, StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean forIntrospection) at System.Reflection.Assembly.InternalLoad(AssemblyName assemblyRef, Evidence assemblySecurity, StackCrawlMark& stackMark, Boolean forIntrospection) at System.Reflection.Assembly.InternalLoad(String assemblyString, Evidence assemblySecurity, StackCrawlMark& stackMark, Boolean forIntrospection) at System.Reflection.Assembly.Load(String assemblyString) at System.Web.Configuration.CompilationSection.LoadAssemblyHelp er(String assemblyName, Boolean starDirective)[ConfigurationErrorsException]: Could not load file or assembly 'SKCLNET, Version=4.2.1.12, Culture=neutral, PublicKeyToken=d5770e63406d04a0' or one of its dependencies. The system cannot find the file specified. (C:\Program Files\HomeSeer 2\html\updater\web.config line 39) at System.Web.Configuration.CompilationSection.LoadAssemblyHelp er(String assemblyName, Boolean starDirective) at System.Web.Configuration.CompilationSection.LoadAssembly(*** emblyInfo ai) at System.Web.Compilation.BuildManager.GetReferencedAssemblies( CompilationSection compConfig) at System.Web.Compilation.WebDirectoryBatchCompiler..ctor(Virtu alDirectory vdir) at System.Web.Compilation.BuildManager.BatchCompileWebDirectory Internal(VirtualDirectory vdir, Boolean ignoreErrors) at System.Web.Compilation.BuildManager.BatchCompileWebDirectory (VirtualDirectory vdir, VirtualPath virtualDir, Boolean ignoreErrors) at System.Web.Compilation.BuildManager.CompileWebFile(VirtualPa th virtualPath) at System.Web.Compilation.BuildManager.GetVPathBuildResultInter nal(VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile) at System.Web.Compilation.BuildManager.GetVPathBuildResultWithN oAssert(HttpContext context, VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile) at System.Web.Compilation.BuildManager.GetVirtualPathObjectFact ory(VirtualPath virtualPath, HttpContext context, Boolean allowCrossApp, Boolean noAssert) at System.Web.Compilation.BuildManager.CreateInstanceFromVirtua lPath(VirtualPath virtualPath, Type requiredBaseType, HttpContext context, Boolean allowCrossApp, Boolean noAssert) at System.Web.UI.PageHandlerFactory.GetHandlerHelper(HttpContex t context, String requestType, VirtualPath virtualPath, String physicalPath) at System.Web.UI.PageHandlerFactory.System.Web.IHttpHandlerFact ory2.GetHandler(HttpContext context, String requestType, VirtualPath virtualPath, String physicalPath) at System.Web.HttpApplication.MapHttpHandler(HttpContext context, String requestType, VirtualPath path, String pathTranslated, Boolean useAppConfig) at System.Web.HttpApplication.MapHandlerExecutionStep.System.We b.HttpApplication.IExecutionStep.Execute() at System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously)-->
Configuration Error
Source Error:
