How do I uninstall this plugin? Where the red X should be in the updater it just says "See plugin config" but there is nothing in there about removing the plugin.
MediaController plugin beta testing Forum
Originally posted by cheeryfool View PostDirk
When is the 3.0.0.20 version going to be posted? I am only seeing .17 which still has the expiry issue. I also check the BETA section just in case
Cheers
James
Dirk
Hi Dirk,
Sorry to bother you, but the issue where my DMR devices don't come back online has returned again. Similar to around #183 of this thread. I've just updated from 3.0.0.17 to 3.0.0.20.
For now I've got my "restart the mediacontroller plugin" event running which gets them online again, so no rush.
If you need any logs or more info let me know.
Cheers
J
Cheers
J
Dirk
Originally posted by Skinnez View PostHi dirk,
Quick note - all working fine with no issues over the weekend!
Cheers
J
I going to let it run a few more days and if all holds up, release a new version later in the week.
Cheers,
Dirk
Hi
i have an Onkyo receiver and if i search it in the UPNP i find it and set it to online.
than i can control the volume and it is working just great
two days after that the receiver will go into a yellow exclamation mark and the receiver will change its status to "alive - failure"
i can stop the plugin and remove all settings file and reenable the plugin and it will be online again for another couple of days.
it means i need to change it in the designer and etc & etc.
any idea?
EDIT:
it seems that if the receiver has been turned off while the plugin was enabled, it will loose connection to it
if i disable and re-enable the plugin, the control is back to normal..
can you do a ping test to check if it is alive like in BLOnkyo?Last edited by ez1976; June 15, 2015, 03:08 PM.
any idea?
There are issues with the more recent version of the MediaController PI. I hope to post later this week a new version, that hopefully takes care of the discover issues.
Do you see any errors in your log?
Dirk
