Hi MikeMack,
Is Linux supported?
Is Linux supported?
homeseer@hs3:~$ ls -l *hspi_scenemaster* -rw-r--r-- 1 homeseer homeseer 213 Oct 20 21:49 Config\hspi_scenemaster_config.xml -rw-r--r-- 1 homeseer homeseer 3641 Oct 19 23:06 Data\hspi_scenemaster\log\scenemaster.txt homeseer@hs3:~$
homeseer@hs3:~$ ls -lR usr usr: total 4 drwxr-xr-x 3 homeseer homeseer 4096 Oct 18 20:32 local usr/local: total 4 drwxr-xr-x 5 homeseer homeseer 4096 Oct 18 20:32 HomeSeer usr/local/HomeSeer: total 12 drwxr-xr-x 3 homeseer homeseer 4096 Oct 18 20:32 bin drwxr-xr-x 3 homeseer homeseer 4096 Oct 18 20:32 docs drwxr-xr-x 3 homeseer homeseer 4096 Oct 18 20:32 html usr/local/HomeSeer/bin: total 4 drwxr-xr-x 2 homeseer homeseer 4096 Oct 18 20:32 hspi_scenemaster usr/local/HomeSeer/bin/hspi_scenemaster: total 0 usr/local/HomeSeer/docs: total 4 drwxr-xr-x 2 homeseer homeseer 4096 Oct 18 20:32 hspi_scenemaster usr/local/HomeSeer/docs/hspi_scenemaster: total 0 usr/local/HomeSeer/html: total 4 drwxr-xr-x 2 homeseer homeseer 4096 Oct 18 20:32 hspi_scenemaster usr/local/HomeSeer/html/hspi_scenemaster: total 0 homeseer@hs3:~$
