Hi Nathan
The Speaker application shows what is below and is using bandwidth as well as other issues. I have found when I turn off the napco plugin this stops any solution to this issue??
THANX
MITCH
/29/2018 2:15:24 PM:Rebuilding VR commands due to configuration change
6/29/2018 2:15:28 PM:Rebuilding VR commands due to configuration change
6/29/2018 2:16:28 PM:Rebuilding VR commands due to configuration change
6/29/2018 2:16:31 PM:Rebuilding VR commands due to configuration change
6/29/2018 2:16:54 PM:Rebuilding VR commands due to configuration change
6/29/2018 2:20:31 PM:Rebuilding VR commands due to configuration change
6/29/2018 2:20:34 PM:Rebuilding VR commands due to configuration change
6/29/2018 2:20:35 PM:Rebuilding VR commands due to configuration change
6/29/2018 2:20:57 PM:Rebuilding VR commands due to configuration change
6/29/2018 2:22:55 PM:Rebuilding VR commands due to configuration change
6/29/2018 2:23:03 PM:Rebuilding VR commands due to configuration change
6/29/2018 2:23:04 PM:Rebuilding VR commands due to configuration change
6/29/2018 2:23:33 PM:Rebuilding VR commands due to configuration change
6/29/2018 2:23:34 PM:Rebuilding VR commands due to configuration change
6/29/2018 2:23:38 PM:Rebuilding VR commands due to configuration change
6/29/2018 2:24:34 PM:Rebuilding VR commands due to configuration change
6/29/2018 2:24:38 PM:Rebuilding VR commands due to configuration change
6/29/2018 2:25:00 PM:Rebuilding VR commands due to configuration change
6/29/2018 2:25:07 PM:Rebuilding VR commands due to configuration change
6/29/2018 2:25:08 PM:Rebuilding VR commands due to configuration change
6/29/2018 2:25:10 PM:Rebuilding VR commands due to configuration change
6/29/2018 2:28:38 PM:Rebuilding VR commands due to configuration change
6/29/2018 2:28:41 PM:Rebuilding VR commands due to configuration change
6/29/2018 2:29:03 PM:Rebuilding VR commands due to configuration change
6/29/2018 2:31:13 PM:Rebuilding VR commands due to configuration change
6/29/2018 2:31:14 PM:Rebuilding VR commands due to configuration change
6/29/2018 2:31:16 PM:Rebuilding VR commands due to configuration change
6/29/2018 2:31:18 PM:Rebuilding VR commands due to configuration change
6/29/2018 2:31:22 PM:Rebuilding VR commands due to configuration change
6/29/2018 2:31:27 PM:Rebuilding VR commands due to configuration change
6/29/2018 2:31:28 PM:Rebuilding VR commands due to configuration change
6/29/2018 2:31:35 PM:Rebuilding VR commands due to configuration change
THANX
MITCH
