Go Back   HomeSeer Message Board > General Home Automation > General Home Automation Hardware Discussion
Old July 11th, 2018, 09:08 AM
aldo's Avatar
aldo aldo is offline
Super Seer
Outside Ethernet box
I have two network cables coming from inside the house to the outdoor. I have them connected with outside camera via a junction box. The cables come inside the box with punch outlet, at the end o have two cat5 cables with the jack. Unfortunately this is not ideal since it is not weatherproof, I searched the internet but I couldn't find anything that is weatherproof. Any suggestions?
Sent from my SM-G935V using Tapatalk
Old July 11th, 2018, 09:15 AM
cc4005's Avatar
cc4005 cc4005 is offline
Seer
There are a lot of options for weather-proof junction boxes and housings but I'm personally not following exactly what you're looking for. Is it a backbox a camera is attached to? Is it attached to a conduit from inside? If you can post a sketch--or better yet a photo of the condition--I'd be happy to try to suggest a solution.
Old July 11th, 2018, 09:34 AM
ewkearns's Avatar
ewkearns ewkearns is offline
Seer Master
https://www.digikey.com/en/product-h...j45-connectors
Enabled Plug-Ins:
2.0.57.0: BLBackup | 3.0.16.0: BLLock | 2.0.24.0: BLUPS | 1.2.5.0: Device History | 3.0.3.10: MeiHarmony Hub | 3.0.0.48 Easy Trigger | 3.0.1.90: PHLocation | 3.0.6681.34300: UltraCID3 | 3.0.6644.26753: UltraLog3 | 3.0.6554.33094: UltraMon3 | 3.0.0.87: weatherXML | 3.0.1.210: Z-Wave | 3.0.51: HS Touch Designer | 3.0.0.40 Z-Seer+
Old July 11th, 2018, 09:40 AM
cc4005's Avatar
Seer
thanks ewkearns good answer I was misreading the question
Old July 11th, 2018, 05:15 PM
aldo's Avatar
Super Seer
Close to what I was looking for, I will send a picture of what I have implemented that is not working right. Thanks for the help.
HTML code is On
USB to ethernet afmiller HS2 / HSPRO 18 February 8th, 2014 03:09 PM
HAI Ethernet mikecoffey HAI/OnQ Panel (HS2) 0 September 1st, 2011 04:26 PM
IR over Ethernet? rmasonjr General Home Automation Hardware Discussion 18 May 19th, 2010 11:01 AM
Ethernet ?? danswatman HomeSeer Global Cache Plug-in 8 May 24th, 2007 10:03 PM
Ethernet crcth3894dthdtnd Elk M1 Plug-In 3 March 4th, 2005 01:24 PM
