I just went through the steps to add the skill - I instructed my Alexa to discover devices. It found everything in my homeseer setup but everything shows as offline. I checked the devices and voice command is checked. As an aside, I have successfully added devices from my Hue so I know that works. Obviously I have done something wrong?
All devices showing offline - Solved!
I just talked to Rich, and it turns out Amazon broke our process when switching us to version 2 of their thermostat code (they have no testing area for the API, it just goes live..., wow!)
We have been in contact with them, and sent them our JSON syntax to try and figure out what is now needed in order for it to work properly.
I'll keep you posted on when they get back to us with a solution.Wade
"I know nothing... nothing!"
Originally posted by Sgt. Shultz View PostI just talked to Rich, and it turns out Amazon broke our process when switching us to version 2 of their thermostat code (they have no testing area for the API, it just goes live..., wow!)
Will await the fix.DSteiNeuro
HS3Pro
Enabled Plug-Ins
garfan
Echo no longer discovers devices
After a few weeks of stable API voice-control over my Homeseer devices, Echo still lists all my 73 previously-discovered devices, but as being OFFLINE now. Tried unlinking/relinking Echo with Homeseer and restarting homeseer. The app says it finds no smart home devices and get "this command does not work with that device" when trying to control devices that used to work rock-solid. Tried FORGETing all devices, but now there's nothing in the device list, offline or otherwise. So disappointed. Running homeseer v 3.0.0.258.
I'm having the exact same issue. At least I found this thread early, so I'll await the fix.
I had Echo and Homeseer perfectly integrated and was loving it.
Originally posted by rjh View PostThis is now fixed, discovery and control should be working.DSteiNeuro
HS3Pro
Enabled Plug-Ins
Back to V1, still working on why V2 is not working. I should be able to post a new URL to register for the V2 when its working so those interested can try it.
Originally posted by drmcp View PostAwesome yes working again, so we on API v1 or V2?
