When using ittt with echo, do you still have to say "tell homeseer to" what ever command? Or you say something else?
Using ittt with echo
IFTTT naming
It should also be noted that the phrase you care about being recognized by Echo is specified in the IFTTT recipe. It is complete separate from the event name. You could have HS run the event "Unlock Door" whenever Echo hears "Wisconsin Moccasins" or "Elephants wear mom's pajamas". Combine to key presses and facial recognition and you have three factor authentication
