I can't remeber the action name but the one that triggers scripts with values from HSTouch text boxes can also do this. Instead of putting the script name in the script name field, you just put in your HS action to perform. Just leave the other fields of the action blank.
I use it to execute scripts without having a textbox with the value to pass. For example I put "&hs.runex("ScriptName.vb","Method","Value") in the field where the script name normally goes.
EDIT: This method is actually covered in the link posted by Rupp.
