Hi folks:
I was previously using a templinc X10 temperature device, but cannot seem to get that going with Homeseer v2. Worked with Homeseer v1.6.
I do have the Insteon plugin from Mark Sandler, but cannot seem to get the templinc to report temperatures.
I would like to replace it with the Venstar Thermostat (Smarthome item 2491T1e) as it would be RF only and I have some powerline issues ... trying to get away from using the powerline if I can help it. I need it to essentially turn on a couple of other insteon units when the temperature rises above, or falls below a certain temperature.
Will this item work with Homeseer if I use the SAGE thermostat plugin?
Best regard, Dave Melnyk
