If you have written a plugin for HS2, please take a moment to take our survey. It will help us fine tune the new HS3 plugin API. We emailed this to all the plugin authors that we have valid emails for, but I am sure we have missed some.
The survey is here:
http://kwiksurveys.com?u=hs3plugins
There is some concern over supporting Linux as some have said they don't know Linux and are not willing to install it. I can understand that. For testing, we will provide a virtual machine image that you can simply download and run. It will have HS3 pre-installed. All you will need to do is copy your plugin to the proper folder to test. Linux support is accomplished under MONO, so as long as your plugin is pure .NET, it should work under MONO on Linux.
The survey is here:
