To use the W800RF32 in the HS3 RFXCOM plug-in configure the receiver with selection box 32 bits receiver enabled.
For all details see chapter 5 in the RFXCOM HS3 User Guide.pdf (is in the HS3 Docs directory)
The HS2 plug-in had also the option to use the W800.
For receiver 1 add or change the ModeRec1=29 parameter in the hspi_RFXCOM.ini Startup section.
The number after ModeRec indicates the receiver number so for receiver 2: ModeRec2=29
