Just purchased the Aeon Multisensor 6 and successfully added it to HS3, creating the root Sensor plus 7 children. However, despite showing Motion as one of them, I cannot get the sensor to show motion to HS3. I've upgraded to the latest sensor firmware 1.6 (1.06 on Aeotec web site), but this has not changed. Any suggestions on how to get motion activities to show up in HS3 show I can start controlling some lighting actions? Running latest Zwave plugin and latest HS3.
Aeon Multisensor 6 - no motion
Originally posted by mdavison View PostJust purchased the Aeon Multisensor 6 and successfully added it to HS3, creating the root Sensor plus 7 children. However, despite showing Motion as one of them, I cannot get the sensor to show motion to HS3. I've upgraded to the latest sensor firmware 1.6 (1.06 on Aeotec web site), but this has not changed. Any suggestions on how to get motion activities to show up in HS3 show I can start controlling some lighting actions? Running latest Zwave plugin and latest HS3.
Cheers
AlHS 4.2.8.0: 2134 Devices 1252 Events
Originally posted by mdavison View PostYes it is. And VERY occasionally it will report motion to HS3....maybe once every couple of hours, in a room where motion is happening fairly constantly.
Cheers
Originally posted by mdavison View PostRunning 3.0.0.199; have set parameter 6 to 64 to try, but does not change characteristics unfortunately.
Cheers
Originally posted by sparkman View PostI believe 64 is the default. Try a higher number (up to 127).
Cheers
Al
Did you get some different information?HS4 Pro, 4.2.19.16 Windows 10 pro, Supermicro LP Xeon
Originally posted by rprade View PostI have attached the parameter sheet Christopher sent me. I don't see parameter 6 for sensitivity, but parameter 4 is.
This is the manual I have which does not even reference parameter 4. I'm waiting for mine to show up so can't actually test it myself yet.
Cheers
Cheers
AlHS4 Pro, 4.2.19.16 Windows 10 pro, Supermicro LP Xeon
Try http://www.pepper1.net/zwavedb/devices
Parameter 4 1 byte is set to 0 by default. Motion disabled.
Set Parameter 4 to range 1 to 5 (max sensitivity)
Seems a daft default value when it is advertised as a multimotion.
Hope that helps
Jo
Hope that helps
Jo
So far so good.
Steve
Thanks for the insight folks. How do you know parameter 4 is set to 5? I know how to use events to set parameters but have yet to figure out how to retrieve them. I feel like Homeseer is amazing but lacks the Z-wave network info you can get from the razberry. I've found the /ZwaveConfig page, but feel like there must be some other pages of detailed info that I am just missing.
Thanks again.
Jim
