I have a simple event that turns on a output relay when motion is detected to enable some speakers. The event runs, and shows the output device turning on, but doesn't actually turn in on mechanically, but shows on in device management.
If I run the event manually, the output devices turns on and all is good. I can manually just turn the device on and off from the Device Management screen and it also works fine.
Using another device in place of the relay, such as a z-wave light, also works fine. Just seems to be with Arduino output devices?
Anyone else noticing this?
